Adding Electric Equation to interFoam (OF 2.3.0)
Old   July 9, 2016, 06:20
mehran
mehranism is on a distinguished road
Dear Foamers,
This is my first thread,so i'll be thankful for any advices.
in order to add electric equations to interFoam i need to add epsilon(permitivity) and KE(electric conductivity) to incompressible two phase mixture. these are two phase variables like density.
my problem is in Modifcation of the library section.
i read all of this thread "http://www.cfd-online.com/Forums/openfoam-programming-development/162577-adding-energy-equation-interfoam-2-4-0-a.html" and used it but it didn't help to solve my case. I am going to describe my steps in detail in this thread like that one:
1)
Copy the original folder transportModels to the user's directory
cd $WM_PROJECT_USER_DIR/src/
cp -rp $FOAM_SRC/transportModels .
2)
Rename the folders and files which are being modified (namely the librariy incompressibleTwoPhaseMixture)
cd transportModels/incompressible
mv incompressibleTwoPhaseMixture myIncompressibleTwoPhaseMixture
cd myIncompressibleTwoPhaseMixture
mv incompressibleTwoPhaseMixture.C myIncompressibleTwoPhaseMixture.C
mv incompressibleTwoPhaseMixture.H myIncompressibleTwoPhaseMixture.H
3)
Change the respective file files corresponding to the the naming and path.
in the folder incompressible/Make for myIncompressibleTwoPhaseMixture:
myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.C
LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleTransportModels
4) Make sure the newly named files are being included with their new name in the respective files:
in myIncompressibleTwoPhaseMixture.C:
#include "myIncompressibleTwoPhaseMixture.H"
5)
Add the new parameters epsilon and KE in myIncompressibleTwoPhaseMixture.H.
////////////////Modified///////////////////
dimensionedScalar KE1_;
dimensionedScalar KE2_;
dimensionedScalar epsilon1_;
dimensionedScalar epsilon2_;
///////////////END////////////////////////
and
/////////////////////////Modified////////////////////////////////////
//- Return const-access to phase1 permitivity
const dimensionedScalar& epsilon1() const
return epsilon1_;
//- Return const-access to phase2 permitivity
const dimensionedScalar& epsilon2() const
return epsilon2_;
//- Return const-access to phase1 elctric conductivity
const dimensionedScalar& KE1() const
return KE1_;
//- Return const-access to phase2 electric conductivity
const dimensionedScalar& KE2() const
return KE2_;
//////////////////////End////////////////////////////////////////
6)
In myIncompressibleTwoPhaseMixture.C add the operations for the new parameters.
////////added/////////////////////////////
KE1_("KE", dimensionSet(-1,-3, 3, 0, 0, 2, 0), nuModel1_->viscosityProperties().lookup("KE")),
KE2_("KE", dimensionSet(-1, -3, 3, 0, 0, 2, 0), nuModel2_->viscosityProperties().lookup("KE")),
epsilon1_("epsilon", dimensionSet(-1, -3, 4, 0, 0, 2, 0), nuModel1_->viscosityProperties().lookup("epsilon")),
epsilon2_("epsilon", dimensionSet(-1, -3, 4, 0, 0, 2, 0), nuModel2_->viscosityProperties().lookup("epsilon")),
///////////end////////////////////////////////
and
nuModel2_->viscosityProperties().lookup("rho") >> rho2_;
//-----------modified_start--------------------//
nuModel1_->viscosityProperties().lookup("KE") >> KE1_;
nuModel2_->viscosityProperties().lookup("KE") >> KE2_;
nuModel1_->viscosityProperties().lookup("epsilon") >> epsilon1_;
nuModel2_->viscosityProperties().lookup("epsilon") >> epsilon2_;
//-----------modified_end----------------------//
Also add the lines for the calculation of kE and epsilon.
// * * * * * * * * * * * * * * calculate the KE & epsilon * * * * //
Foam::tmp<Foam::volScalarField>
Foam::myIncompressibletwoPhaseMixture::KE() const
const volScalarField limitedAlpha1
min(max(alpha1_, scalar(0)), scalar(1))
return tmp<volScalarField>
new volScalarField
"KE",
limitedAlpha1*KE1_
+ (scalar(1) - limitedAlpha1)*KE2_
Foam::myIncompressibletwoPhaseMixture::epsilon() const
new volScalarField
"epsilon",
limitedAlpha1*epsilon1_
+ (scalar(1) - limitedAlpha1)*epsilon2_
// * * * * * * * * * * * * * * end * * * * * * * * * * * * * * //
7)
Compile the library from the respective folder.
cd incompressible
wclean
wmake libso
files are attached below:
mehranism is offline   Reply With Quote
Old   July 9, 2016, 06:22
mehran
i did this and I got the following output log:
myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.C:166:45: error: no ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::myIncompressibleTwoPhaseMixture::KE() const’ member function declared in class ‘Foam::myIncompressibleTwoPhaseMixture’
myIncompressibleTwoPhaseMixture/myIncompressibleTwoPhaseMixture.C:186:50: error: no ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::myIncompressibleTwoPhaseMixture::epsilon() const’ member function declared in class ‘Foam::myIncompressibleTwoPhaseMixture’
make: *** [Make/linux64GccDPOpt/myIncompressibleTwoPhaseMixture.o] Error 1
any idea to solve this?
Old   July 9, 2016, 18:52
mehran
i solved that error...
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
interface smearing. InterFoam, OpenFOAM 2.3.0 and higher vagnerserge OpenFOAM Running, Solving & CFD 4 February 4, 2019 07:56
adding energy equation to interFoam Elham OpenFOAM Programming & Development 11 January 29, 2017 14:14
Adding temperature to interFoam, openFOAM version 2.3.0 abdessamad OpenFOAM Programming & Development 0 May 9, 2014 08:27
Adding an Acoustic Equation Prateep Chatterjee FLUENT 0 June 2, 2000 10:22
