August 19, 2016, 11:05 |
One linear system for two mesh regions
Rep Power: 11 |
Hey,
I have a question about coupling two regions. Let's say I've connected regions A and B. I want to solve the same equation on both meshes. I can't merge the two meshes because there are additional equations solved on only one of the meshes. Is it possible to create only one linear system for both meshes? So a coupling boundary between these meshes wouldn't be necessary. Or is there any useful coupling BC (scalar and vector) for this case? Thanks in advance for your help! |
August 19, 2016, 11:50 |
Sergei
Rep Power: 21 |
conjugateHeatFoam from foam-extend migh be what you are looking for:
https://sourceforge.net/p/openfoam-e...ugateHeatFoam/ http://www.tfd.chalmers.se/~hani/kur...ssonReport.pdf http://www.cfd-online.com/Forums/ope...am-solver.html |
August 19, 2016, 14:10 |
Rep Power: 11 |
Thanks, that looks promising but unfortunately it's included in foam-extend and not OpenFOAM. Some experience in porting it to OpenFOAM or is there something similar in OpenFOAM?
August 19, 2016, 14:58 |
Sergei
Rep Power: 21 |
AFAIK, there's no analog of conjugateHeatFoam in OpenFoam.
August 24, 2016, 12:58 |
Mahdi Hosseinali
Rep Power: 18 |
You can use parts of the FOAM-ext along with your original foam (if the dependencies are not too much).
try this link: http://www.tfd.chalmers.se/~hani/kur...rtReviewed.pdf It shows you how to port a BC from ext, also is a famous tutorial on how to add T to cavity case. Having these two you should be able to get conjugateHeatFoam on your current version. |
pimpleDyMfoam , AMI -- The mesh has multiple regions not connected by any face | coolcrasher | OpenFOAM Running, Solving & CFD | 3 | May 16, 2019 05:58 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
how to modify fvScheme to converge? | immortality | OpenFOAM Running, Solving & CFD | 15 | January 16, 2013 13:06 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
