my solution depends on writeInterval entry in the controlDict |
September 2, 2016, 08:15 |
Przemek
Rep Power: 15 |
Hi
I found that my solution depends on writeInterval entry in the controlDict. How is it possible?
best regards pblasiak |
September 2, 2016, 11:14 |
Since question lacks lots of details, answer is in fact question: does your time step value depend on writeInterval? |
September 3, 2016, 12:54 |
Przemek
Rep Power: 15 |
Hi alexym,
I am using modified interPhaseChangeFoam from OpenFOAM extend 3.0 I set adjustTimeStep to "no" and the results also depend on the writeInterval entry. Namely, the interface position varies significantly when I decrease writeInterval, for example from 0.1 to 0.01. Is it bug?
September 3, 2016, 12:57 |
Przemek
Rep Power: 15 |
what can be the reason? I do not understand.
In the code I have temperature equation with term fvm::ddt(rho, T) and I used rho.oldTimes() method in createFields.H for rho. Does rho.oldTimes() method store the previous iteration or previous time step values?
September 3, 2016, 13:57 |
1. Does you solution depend on time step? 2. What modifications did you make? 3. What convergence criterion do you utilize (if any)? Yes, it could be bug in: 1. your solver modification 2. your case setup 3. original solver In general oldTime stores noting: http://cpp.openfoam.org/v4/a00931.ht...09ca405ce907a6 (though in foam-extend this could be different). There are storePrevIter (http://cpp.openfoam.org/v4/a00931.ht...7c72a819c66706) and storeOldTimes (http://cpp.openfoam.org/v4/a00931.ht...9ee55d9138fd4d) if you want to store things. |
September 6, 2016, 05:44 |
Przemek
Rep Power: 15 |
Hi alexeym,
Thank you for your help. I found that it is bug in my code but for now I do not know where
September 6, 2016, 06:22 |
Przemek
Rep Power: 15 |
I used in the code this line to relax TEqn
TEqn.relax(0.9); is it the same if I have in the code TEqn.relax(); and in the fvSolution dictionary: relaxationFactors { equations { T 0.9; } } ??
September 7, 2016, 04:12 |
Since you relax unconditionally, it corresponds to
relaxationFactors { equations { "T.*" 0.9; } } |
September 7, 2016, 08:31 |
#9 |
Przemek
Rep Power: 15 |
Hi alexeym,
I commented the line with TEqn.relax() and now the results almost does not depend on writeInterval entry. For instance I got liquid volume fraction after 10 s as: Code:
VOF writeInterval 0.513542 1.0 0.513706 0.1 0.517829 0.01 0.522513 0.001 0.519461 0.0001
September 9, 2016, 01:51 |
#10 |
Surely it is very fascinating game called "guess what I have done wrong", and lots of people on the forum like to play it. As I have written earlier: if your solution depends on time step, check your convergence. Did you? Are your time steps equal and smaller than writeInterval in all cases? |
September 9, 2016, 03:55 |
#11 |
Przemek
Rep Power: 15 |
I checked convergence and set timestep to be fixed
CFL Condition | Matt Umbel | Main CFD Forum | 19 | June 30, 2020 08:20 |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Doubt on Implicit Methods | analyse In India | Main CFD Forum | 10 | March 9, 2007 03:01 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
