read a .dat file with fseek and fscanf problem
Like Tree2Likes
  • 1 Post By federicabi
Old   September 23, 2016, 02:46
Question read a .dat file with fseek and fscanf problem
Federica Biano
federicabi is on a distinguished road
Hello!
I need your precious help to solve my problem.
I've never programmed in C++ and I tried recently to modify a library in sixDoFRigidBodyMotion. When I compiled it no errors came out, but when I run the code results are completely wrong.
Let me explain: I need to read for each timestep the forces.dat file and in particular the last line of it and take only two force's components. I used the functions fseek to go to the end of file and return at the beginning of the last line, and the function fscanf to read the line and save the two force's components into two variables.
This is my code
FILE *forze;
      forze = fopen("postProcessing/forces/1/forces.dat", "r");
      float timestep;
      float fxp;
      float fyp;
      float fzp;
      float fxv;
      float fyv;
      float fzv;
      float fxpo;
      float fypo;
      float fzpo;
      float mxp;
      float myp;
      float mzp;
      float mxv;
      float myv;
      float mzv;
      float mxpo;
      float mypo;
      float mzpo;
      fseek(forze,-271,SEEK_END);
      fscanf(forze, "%f    ((%le %f %f) (%le %f %f) (%f %f %f)) ((%f %f %f) (%f %f %f) (%f %f %f))", &timestep, &fxp, &fyp, &fzp, &fxv, &fyv, &fzv, &fxpo, &fypo, &fzpo, &mxp, &myp, &mzp, &mxv, &myv, &mzv, &mxpo, &mypo, &mzpo);
      fclose(forze);
      forzaxPrevIter = fxp + fxv + fxpo;
      alfaPrevIter = (alfaini_ * 3.1415 / 180) + asin(motion.orientation()[3]);
      alfa = alfaPrevIter;
      forzax = forzaxPrevIter;
    restraintPosition = motion.transform(refAttachmentPt_);
    vector v = motion.velocity(restraintPosition);
    restraintForce = vector((-1)*forzax,0,(-1)*forzax*tan(alfa));
    restraintMoment = vector::zero;
What returns when the code is running aren't the force's components but the pointer values (I think) because they don't change every timestep but they change if I run another simulation.
What can I do to solve it? I tried also to make a C++ program and it does what I need, but when I put the code into openfoam it doesn't anymore.
Any help would be very appreciated!
Federica
ordinary likes this.
federicabi is offline   Reply With Quote
Old   September 27, 2016, 10:56
Default solved
Federica Biano
If you are interested in the correct code, there you are:
FILE *forze;
      float timestep;
      float fxp;
      float fyp;
      float fzp;
      float fxv;
      float fyv;
      float fzv;
      float fxpo;
      float fypo;
      float fzpo;
      float mxp;
      float myp;
      float mzp;
      float mxv;
      float myv;
      float mzv;
      float mxpo;
      float mypo;
      float mzpo;
      char c;
      fseek(forze,-285,SEEK_END);
      while(c != '\n')
    c=fgetc(forze);
      fscanf(forze, "%f    ((%f %f %f) (%f %f %f) (%f %f %f)) ((%f %f %f) (%f %f %f) (%f %f %f))", &timestep, &fxp, &fyp, &fzp, &fxv, &fyv, &fzv, &fxpo, &fypo, &fzpo, &mxp, &myp, &mzp, &mxv, &myv, &mzv, &mxpo, &mypo, &mzpo);
      fclose(forze);
Regards
Old   February 20, 2017, 14:35
Emre
ordinary is on a distinguished road
Did you solve the problem? It seems interesting.
ordinary is offline   Reply With Quote
