Looking for paper "Implementation of level set method ..." by Bitan Shu, et al
Like Tree1Likes
Old   April 5, 2010, 16:27
Default Dear Professor Hjasak
  #21
Javier Basurco
Ingenierias2003 is on a distinguished road
My name is Javier Basurco I am doing my PhD in Mechanical Engineering in Rio de Janeiro. I am working with modeling of slug flow of air - water two - phase flow. I am using Fluent to simulate this pattern. When I know the OpenFOAM I stay very intersted in about the software. In the first moment I am compare my solution from fluent to OpenFOAM with VOF method my next step is implement a level set method to compared which method reconstructed better the interface.
I woul like to advice in this way, I really appreciated your advice to programming.
Thanks for the pacience
Respectfully
Javier Basurco
Originally Posted by hjasak View Post
Yes, I have done level set. Make two fields, with different boundary conditions. Run the normal solver on the first, reinitialisation on the second and copy the result.
Enjoy,
Hrv
Ingenierias2003 is offline   Reply With Quote
Old   April 8, 2010, 10:29
Default May I ask for the paper as well?
  #22
GRD
g.redondo is on a distinguished road
Regards,
Gonzalo
g.redondo is offline   Reply With Quote
Old   April 9, 2010, 05:42
Gijsbert Wierink
gwierink is on a distinguished road
Hi Gonzalo,
You can get the paper from the Open Source CFD 2007 conference proceedings here. Are you working/planning to work with level set? I am tying to develop some bubble model with it ... but is work in progress ...
Regards, Gijs
gwierink is offline   Reply With Quote
Old   April 9, 2010, 06:02
GRD
Actually not yet, just gathering info
Old   April 29, 2010, 12:36
Post paper
  #25
ak2009 is on a distinguished road
Hi...
I am using level set method to study the interface behavior in two phas flows (surface aeration).
I came across the link to below paper by Bitan Shu. Would it be possible to refer to this paper ?
Implementation of level set method based on OpenFOAM for Capturing the free interface in incompressible fluid flows
my email address is akforu2000@yahoo.co.in
ak2009 is offline   Reply With Quote
Old   April 30, 2010, 04:19
Gijsbert Wierink
Hi ak2009,
Ehm, of course ... What is your question really?
Just follow the link above in my post.
Regards, Gijs
Old   April 30, 2010, 04:37
Post paper
  #27
Thanks Gijs,
I checked the link. However could not download it due to some internet problems.
Can you send the soft copy.
My email address is akforu2000@yahoo.co.in
Thanks
Ajit
Old   April 30, 2010, 07:57
Gijsbert Wierink
Hi Ajit,
Sure, I'll send it right away .
Regards, Gijs
Old   May 1, 2010, 06:09
Post paper
  #29
Thanks Gijsbert.
Received both the article and ppt.
Thanks
Ajit
Old   December 6, 2011, 10:54
Default level set with VOF MODEL fluent
  #30
Ishan Khan
ishancd is on a distinguished road
Am currently working with the motion of a single bubble in a flowing fluid. I didnt understand what you said in youre comment about re-initialization and running the solver seperately for the second one. I am relatively new in fluent and am having trouble how to couple the level set function with VOF model. Can you take some time out and provide me with a step by step process (or a tutorial ) on how to do that ? Will be grateful.My email address is ishancd@yahoo.com
ishancd is offline   Reply With Quote
Old   December 7, 2011, 03:02
Kathrin Kissling
kathrin_kissling is on a distinguished road
ishan,
this is OpenFOAM not Fluent.
But for coupling level-set and vof read the articles of sussman, and the ones which reference him! Theres a lot out there.
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   November 4, 2013, 15:40
Friederike is on a distinguished road
Hallo Matthias,
did you find out what BC's need to be set? If so could you give me a hint?
Friederike
Friederike is offline   Reply With Quote
Old   April 16, 2015, 04:20
Default Inplementation of Level Set
  #33
Marco Polo
marco.espinoza is on a distinguished road
I am very new in OpenFoam and I am working in the implementation of Level Set in interFoam solver. I created the fields necessaries for the method; however, I don't understand how I can initialize the level set function. Can help me? I am reading Implementation of the Level Set Method into OpenFOAM for captiring the Free Interface in Incompressible Fluid Flows by Bitan Shu.
Thank you
marco.espinoza is offline   Reply With Quote
Old   April 16, 2015, 07:35
Hey Marco,
initializing the level-set-function can be done by using the application funkySetFields which is part of swak4foam.
https://openfoamwiki.net/index.php/Contrib/swak4Foam
Best regards
Friederike
Old   July 12, 2015, 09:09
Freedom
wenxu is on a distinguished road
Could anyone in this thread send Bitan's paper to me? Thank you in advance!
981588592@qq.com
regards,
Wen Xu
wenxu is offline   Reply With Quote
Old   July 15, 2015, 09:01
Freedom
Hi, Gijsbert.
Could you send the paper to me? Thank you very much!!!
Best regards,
Wen
Old   July 15, 2015, 09:26
Gijsbert Wierink
Hi Wen,
Sorry, can't find the article. I guess the best would be to ask Bitan Shu personally: http://www.tecies.de
Regards, Gijs
Old   July 15, 2015, 09:38
Freedom
Thank you for the link!
regards,
wen
Old   July 31, 2015, 10:13
Default field intialization for level set
  #39
Mostafa Mobli
moblimostafa is on a distinguished road
Is there anybody who have successfully implemented Level Set in OpenFoam? I have some questions about the implementation.
How Should I initialize the field? I have read that I can do this with funkySetFields but I couldn't figure out how to initialize the field as a signed distance function from the interface.
I also have some questions about the flux calculations.
Thanks for your reply in advance
moblimostafa is offline   Reply With Quote
Old   August 1, 2015, 21:03
Freedom
Could you tell me how you reinitialize the level set field?
regards,
Wen
setting of level set method as initial condition sooroo3 FLUENT 4 July 31, 2018 04:20
calculating Normal vector in level set method amir2920 Main CFD Forum 1 July 21, 2009 07:25
Level set vs VOF steve Main CFD Forum 11 September 16, 2008 00:22
level set for multi-fluids system? Pei-Ying Hsieh Main CFD Forum 1 July 19, 2000 16:42
level set method with TVD scheme? zhanglei Main CFD Forum 1 April 25, 2000 14:01
