Home > Forums > OpenFOAM Programming & Development
question about swirlMassFlowRateInletVelocity boundary type
Old   March 19, 2009, 06:33
Default question about swirlMassFlowRateInletVelocity boundary type
parham momeni
mcjicpm2 is an unknown quantity at this point
I am trying to use the swirlMassFlowRateInletVelocity boundary type:written by olesen in the following discussion room
Bc in cylindrical coordinates
as below:
You might try the swirlMassFlowRateInletVelocity boundary type:
swirlbc.tar.gz
Description
Describes an massflow normal vector boundary condition by its
magnitude as an integral over its area, with a swirl component.
The current density is used to correct the velocity.
Note: The value is positive for inward pointing vectors
Swirl is defined in RPM about the patch centre-axis according
to a right-hand rule (inwards axis).
Only useful for planar patches.
Example of the BC specification:
inlet
type swirlMassFlowRateInletVelocity;
massFlowRate 0.2; // [kg/s]
rpm 5000;
Can anybody please tel me after I downloaded the files what should I do after? where should I copy the files? should I compile something?
please help me since I am very new to openfoam and it is needed for me to learn it .
mcjicpm2 is offline   Reply With Quote
Old   April 24, 2009, 05:30
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
I don't know if it is too late, but I'll try to help you and to get some help too.
I was suggested to install all personal applications in OpenFOAM\<user>-<version> folder, not to mix with OpenFOAM's already installed applications.
In the case of one new BC, you can copy the files into the \src\<newBC> folder, for example. After that, you have to create one other folder, named Make, in the same address of the .C file. In this Make folder, you need to create two files: options and files. So in the end you'll have something like:
OpenFOAM\<user>-<version>\src\<newBC>
- <newBC>.C
- Make\files
- Make\option
(in general, you may have more than just one .C and even some .H files)
And I can't help you anymore...here I'll ask somebody to explain what I should exactly write in these Make\files and Make\options.
I think that in the Make\files we must list the files that are going to be compiled and at the end, the address and name of the file (.so, in this case) that will be created. For this case (swirlMassFlowRateInletVelocity), I tried:
swirlMassFlowRateInletVelocityFvPatchVectorField.C
LIB = $(FOAM_USER_LIBBIN)/swirlMassFlowRateInletVelocity
In the case of the Make\options, I just know we have to show what libraries etc will be needed during the compilation (with -I), but I can't understand the meaning of the rest of the code. In this case, I have:
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
-lfiniteVolume
After I give the wmake libso comand, I receive some error messages (backslash-newline at the end of file, no match function to call etc) and no library is created.
Could anybody help?
Thank you,
Leo
leonardo.morita is offline   Reply With Quote
Old   April 28, 2009, 04:08
Hello again,
After some help from Mark, the code's developer, I could finally solve my problem. Here is a brief guide for those who have the same problem:
1. The organisation of the files is very important and it is higly recommended to keep your own applications in your personal folder, OpenFOAM/<user>-<version>. So you should/may have (you can replace src by one other folder, like a foamUser, for example):
~/src/
~/src/Make/
~/src/Make/files
~/src/Make/options
~/src/<newlib>/
~/src/<newlib>/<file>.C
~/src/<newlib>/<file>.H
~/src/libfoamUser.C
where, in this case:
<newlib> = swirlFlowRateInletVelocity
<file>.C = swirlFlowRateInletVelocityFvPatchVectorField.C
<file>.H = swirlFlowRateInletVelocityFvPatchVectorField.H
2. The content of the Make/files file is:
<newlib>/<file>.C //relative address of the file to be compiled
libfoamUser.C
LIB = $(FOAM_USER_LIBBIN)/libFoamUser
3. And that of the Make/options is:
EXE_INC = \
LIB_LIBS = \
-lfiniteVolume
4. The only library that will be created is libfoamUser.so, which will gather information about all your own libraries listed in the Make/files file. If you want to add some other library later, all you have to do is to create a new folder with the .C and .H files and to put an extra line in the Make/files, like:
5. Once the files are well placed, you can compile it using wmake libso in the ~/src/ folder
Hope this will be useful!
Old   November 16, 2009, 14:41
Tian
tian is on a distinguished road
it is also working for the OpenFOAM 1.5-dev Version?
Bye
Thomas
tian is offline   Reply With Quote
Old   November 17, 2009, 14:16
Tian
I changed the code for OpenFOAM-1.5-dev Version. Thanks
Bye
Tian
Old   August 28, 2014, 03:08
Default Modify swirlFlowRateInletVelocityFvPatchVectorField
Ndong-Mefane Stephane Boris
S_teph_2000 is on a distinguished road
I would like to modify swirlFlowRateInletVelocityFvPatchVectorField in order to use velocity components (in cylindrical coordinates if possible) instead of rpm. I will also add that each velocity component is a function of the radial component of U.
instead of:
rpm 5000;
we would have
Ur = f1(r); //I also need to find a way to input an expression "f(r)" instead of a value. maybe with Swak{...}, or groovyBC???
Ut = f2(r);
Uz = f3(r);
with r=x^2+y^2
I an trying to set the BC for the inlet of a steam turbine...HELP PLEASE!!
Stephane
S_teph_2000 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Invalid boundary type name blobloblo OpenFOAM Installation 1 June 9, 2008 11:21
what is 'interior' boundary type Muhammad Usman Qureshi FLUENT 3 July 25, 2007 14:57
boundary conditions' type (UDF) Doru Grosan FLUENT 0 August 24, 2005 10:22
Transient Boundary Type Prakash Verma FLUENT 0 March 1, 2005 17:00
Change Boundary type? ccc FLUENT 6 January 15, 2004 06:24
