A Parallelization Issue
Old   July 9, 2009, 10:19
Default A Parallelization Issue
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers,
I wrote a synthetic turbulence model that is based on a filter equation, so:
u(x,y,z) = Int over Vol (A(x',y',z')*K(x',y',z')*u'(x',y',z') dV)
Int is integral, and Vol is a portion of the volume around the cell (x,y,z).
The code is ok for scalar computation, now I would like to parallelize it.
The problem is that, as you can see, the filter equation require informations from several neighbouring cells. I thought that one possible approach is to save the needed cells that are across a processor boundary at the beginning, and then pass with Pstream them on run time. Could it be a sufficient solution? And, can I access, for each single processor, a "global" mesh index?
ivan_cozza is offline   Reply With Quote
Simple Frustrating Meshing Issue in Gambit (w/pics) Dylan ANSYS Meshing & Geometry 6 March 23, 2009 16:14
Memory issue - Suse 10 - Opterons Andy R FLUENT 1 June 23, 2008 14:44
STAR-CD Dynamics issue 16 CD adapco Group Marketing Siemens 0 November 30, 2001 10:25
Issue 4 of adapco-online Sreenadh Jonnavithula Main CFD Forum 8 January 5, 2001 13:40
Issue 4 of adapco-online Sreenadh Jonnavithula Siemens 0 December 21, 2000 13:41
