June 22, 2009, 09:47 |
how to implement this kind of source term
mihamina keisha
Rep Power: 16 |
hi there,
I'm implementing a source term in my model and I'm stuck,here it is: volScalarField rpyro = kncell*wncell*rho*exp(Encell/(R*Ts)); and here what it says when I run it: "Argument of transcendental function not dimensionless" I don't know but it clearly says in the guide that to implement exponantial function we need to type exp(term),I defined the dimension for each term but I don't know what' wrong with it. I've checked out the trans() function and I know it but the point is that I didn't even use it. Can somebody out there tell me how to work this out please? Thanks in advance. |
June 22, 2009, 19:43 |
Rep Power: 18 |
Hi keishawillstone
(sorry could not find your real name) I am not sure if this will help but just try this way: volScalarField rpyro = kncell*wncell*rho*Foam::exp(Encell/(R*Ts)); If that does not help then please try a more descriptive post as in this case it is not clear what are Encell, R and T. Are they volScalarFields or just scalars . BR Jaswi |
June 23, 2009, 05:44 |
information
mihamina keisha
Rep Power: 16 |
Hi Jaswi,
I want to thank you first for answering me.By the way,about the precision, kncell is a scalar wncell is a scalar Encell is also a scalar R is constant used in the perfect gas law(scalar) Ts is the temperature(volScalarField) But I will try it and keep you aware of the result BR, Keisha |
June 23, 2009, 06:04 |
#4 | |
Niklas Nordin
Rep Power: 29 |
make the scalars dimensionedScalars instead and make sure the argument to exp is dimensionless. |
June 24, 2009, 06:38 |
mihamina keisha
Rep Power: 16 |
Hi there,
What really puzzles me is that I landed on the analytical cylinder code in potentielFoam and it uses cos() and sin() though these laters are considered as transcendental function and the code didn't even included any specific header but just 'fvCFD.H'. Thank you for the information I will try it and keep you inform BR Keisha |
June 24, 2009, 08:01 |
Rep Power: 18 |
Hi There
Yes you are right but please look into the fvCFD.H and you will realize that it is the mother of all headers. take a look 00001 #ifndef fvCFD_H 00002 #define fvCFD_H 00003 00004 #include "parRun.H" 00005 00006 #include "Time.H" 00007 #include "fvMesh.H" 00008 #include "fvc.H" 00009 #include "fvMatrices.H" 00010 #include "fvm.H" 00011 #include "linear.H" 00012 #include "calculatedFvPatchFields.H" 00013 #include "fixedValueFvPatchFields.H" 00014 #include "adjustPhi.H" 00015 #include "findRefCell.H" 00016 #include "mathematicalConstants.H" 00017 00018 #include "OSspecific.H" 00019 #include "argList.H" 00020 #include "timeSelector.H" 00021 00022 #ifndef namespaceFoam 00023 #define namespaceFoam 00024 using namespace Foam; 00025 #endif 00026 00027 #endif it lives at src/finiteVolume/cfdTools/general/include/fvCFD.H BR Jaswi |
June 25, 2009, 09:03 |
mihamina keisha
Rep Power: 16 |
Hi there,
Thank you so much it works well,the argument should be dimensionless!!!! |
July 24, 2009, 13:51 |
isabel
Rep Power: 16 |
Sorry for disturb you. Do you know how to correct my error?
My code is: forAll(levelSet,gI) { if (levelSet[gI] > 0.0002 ) H[gI] = 1; else { if (levelSet[gI] < 0.0002 ) H[gI] = 0; else H[gI] = sin(levelSet[gI]); } } And when I compile, I have this error in the line " H[gI] = sin(levelSet[gI]) " : levelSetEqn.H:91: error: call of overloaded ‘sin(double&)’ is ambiguous |
July 24, 2009, 14:14 |
#9 |
Henrik Rusche
Rep Power: 18 |
Isabel,
Please do not post the same question all over the place. Henrik |
Display Modes | |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
