Hi Matvej
I have advanced a bit ahead with my last problem. The previous error is sorted out. it was because of the difference in meshing and boundary condition. However I am still wondering with the question of different implementation of p-equation. I mean.. when we use phi in pEqn (), we use phi += pEqn.flux(); And when we use phid etc then we use phi = pEqn.flux(); I am still wondering why?? Any hint please? regards, Nishant |
Hi, I'm very sorry for late reply (too much work).
Anyway, if this answer is still needed: when we update velocity (phi = velocity*density*area) in diffusion pressure equation, we mean that dU ~ const * grad(dp). If we are using convection-diffusion equation for pressure: ddt(psi,p) + div(phi_d, p) - div(rho/A*grad(p)), we are solving for mass flux, which satisfies continuity equation. Another words: - diffusion equation - correction to mass fluxes (to satisfy continuity) - phi+=pEqn.flux() - convection-diffusion - mass fluxes, which continuity - phi=pEqn.flux() I hope, this helps you. I'm really sorry for late post |
please would you guide me in running a new application on OpenFOAM
i am new to OpenFOAM.
i was going through the "OpenFOAM Programming Tutorial" written by Tommaso Lucchini. i modified icoFoam to icoScalarTransportFoam and cavity to cavityScalarTransport in accordance to the directions of the notes. now i cannot set up the case cavityScalarTransport and cannot run it. would you please guide me with the commands for running this new application.thanking you in advance. |
