October 23, 2009, 12:46 |
#21 |
Nishant
Rep Power: 17 |
Hi Matvej
I have advanced a bit ahead with my last problem. The previous error is sorted out. it was because of the difference in meshing and boundary condition. However I am still wondering with the question of different implementation of p-equation. I mean.. when we use phi in pEqn (), we use phi += pEqn.flux(); And when we use phid etc then we use phi = pEqn.flux(); I am still wondering why?? Any hint please? regards, Nishant |
November 5, 2009, 14:16 |
#22 |
Matvey Kraposhin
Rep Power: 21 |
Hi, I'm very sorry for late reply (too much work).
Anyway, if this answer is still needed: when we update velocity (phi = velocity*density*area) in diffusion pressure equation, we mean that dU ~ const * grad(dp). If we are using convection-diffusion equation for pressure: ddt(psi,p) + div(phi_d, p) - div(rho/A*grad(p)), we are solving for mass flux, which satisfies continuity equation. Another words: - diffusion equation - correction to mass fluxes (to satisfy continuity) - phi+=pEqn.flux() - convection-diffusion - mass fluxes, which continuity - phi=pEqn.flux() I hope, this helps you. I'm really sorry for late post |
June 25, 2013, 08:40 |
please would you guide me in running a new application on OpenFOAM
#23 |
Anil Kunwar
Rep Power: 11 |
i am new to OpenFOAM.
i was going through the "OpenFOAM Programming Tutorial" written by Tommaso Lucchini. i modified icoFoam to icoScalarTransportFoam and cavity to cavityScalarTransport in accordance to the directions of the notes. now i cannot set up the case cavityScalarTransport and cannot run it. would you please guide me with the commands for running this new application.thanking you in advance. Last edited by Annier; July 23, 2013 at 02:03. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
