simpleFoam with energy equation
Old   October 13, 2009, 12:49
Default simpleFoam with energy equation
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello world.
I'm dealing with a case in which Navier-Stokes and energy equation can be solved one after the other.
I have little experience in manipulating solvers, but I think it's possible to alter the simpleFoam solver for such a case.
So where do I put the energy equation?
As I want to compute temperature after successfully converged Navier-Stokes-Equation I have thought about opening another time-loop and solving the energy equation there.
Something like this:
   Info<< "\nStarting time loop\n" << endl;
    for (runTime++; !runTime.end(); runTime++)
        Info<< "Time = " << runTime.timeName() << nl << endl;
#       include "readSIMPLEControls.H"
#       include "initConvergenceCheck.H"
        p.storePrevIter();
        // Pressure-velocity SIMPLE corrector
#           include "UEqn.H"
#           include "pEqn.H"
        turbulence->correct();
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
#       include "convergenceCheck.H"
#include 'TEqn.H'
    Info<< "End\n" << endl;
    return(0);
TEqn.H will contain the energy equation. So much for the basics of this problem.
Thanks for your ideas. See you.
Sebastian
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   October 14, 2009, 02:57
Markus Rehm
markusrehm is on a distinguished road
Hi Sebastian,
have a look at buoyantSimpleFoam.
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   October 19, 2009, 14:04
sega's Avatar
Sebastian Gatzka
Originally Posted by markusrehm View Post
Hi Sebastian,
Regards, Markus.
I did and it looks to me that the enthalpy equation is solved inside the brackets with U and p.
So I will put the energy equation inside it too?
#           include "UEqn.H"
#           include "pEqn.H"
#           include "TEqn.H"
Just to make sure...
Old   November 20, 2009, 14:21
sega's Avatar
Sebastian Gatzka
It took some time before I got back to this construction site:
Do you think buoyantSimpleFoam for itself (without chaning anything) will be the right choice for a simple convective heat transfer problem?
Old   November 23, 2009, 02:31
Markus Rehm
It worked well for me. But you can take out the buoyancy term as well.
Markus
Old   January 25, 2013, 15:05
Default TEqn.H
Suranga Dharmarathne
sdharmar is on a distinguished road
Hi Markus and Sebastian,
Why can't we put the TEqn.H out side the SIMPLE loop. I think we need to calculate temperature field after we got corrected velocity field. Is my idea right or wrong? And since simpleFoam calculates turbulent flows I put my Teqn.H as,
volScalarField kappaEff
"kappaEff",
turbulence->nu()/Pr + turbulence->nut()/Prt
fvScalarMatrix TEqn
//fvm::ddt(T)
fvm::div(phi, T)
- fvm::laplacian(kappaEff, T)
TEqn.relax();
TEqn.solve();
//rhok = 1.0 - beta*(T - TRef);
Please correct me if I am wrong. My temperature value fluctuates a lot whenever I used it out side the SIMPLE loop. But in pisoFoam I put it in outside the PISO loop and worked really good.
Please advice me.
Best regards,
Suranga.
sdharmar is offline   Reply With Quote
Old   January 26, 2013, 06:42
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi Suranga
I think the (rather old) discussion here was about the time loop not the Simple/pimple loop. Naturally one needs to keep the algorithm for the Navier-Stokes equations intact. You can add whatever equation outside the algorithm to let it resole the pressure-velocity coupling in peace. Of course all equations should be inside the time loop unless you need to solve an equation once.
Hisham
Hisham is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Need help:about energy equation in CFX Stein CFX 4 July 2, 2009 22:31
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
question about energy equation zhou FLUENT 0 February 23, 2004 23:55
