October 19, 2009, 15:25 |
Export a C code
Vitor Braga
Rep Power: 16 |
Is it possible to export a C written code to OpenFOAM?
For example, if Im looking forward to expressing a variable boundary condition (let's assume a senoid), can I write it in C and use it as an input to OpenFOAM? Like in Fluent there are the UDF's (user defined functions). Thank you, very much. Regards. Vitor Braga |
October 20, 2009, 02:10 |
#2 | |
Mark Olesen
Rep Power: 40 |
It'll depend on what type of bc you have (fixed, gradient, mixed), but you could take one of the timeVaryingXXX boundary conditions from OpenFOAM as a starting point and define your things as 'extern C' binding (presuming they are in an external library. The other possibility is just to compile your existing C code as C++ as part of your new OpenFOAM bc. |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
CFD Code with Fortran | murat | Main CFD Forum | 0 | October 11, 2009 17:05 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 13:22 |
