November 26, 2009, 17:20 |
nAlphaCorr and nAlphaSubCycles
Santiago Marquez Damian
Rep Power: 23 |
Hi all FOAMers, I'm preparing a document about scalarTransportFoam, icoFoam and interFoam (coming soon) and can't figure the necessity and differences between nAlphaCorr and nAlphaSubCycles in interFoam code, What are each one for?
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
October 6, 2010, 17:49 |
Lars Kiewidt
Rep Power: 16 |
Hi Santiago,
although it is an old thread, have you find out the difference, yet? I'm using OF-1.6 and had a look at the alphaEqnSubCycle.H file. There nAlphaCorr is just read but never used. Thanks! Lars |
October 6, 2010, 18:18 |
Rep Power: 23 |
Lars, subCycling is explained in Berberovic's paper, basically actual temporal step is subdivided n times, then advective equation for alpha is integrated these n times and then divided by the hole timestep, is a kind of temporal filtering in order to improve stability.
As regards alpha corrections, they are used in a fixed point iteration over alpha to improve the quality of solution. Respect of this, I haven't done too much research in the convergence of this iteration, etc. Regards.
October 6, 2010, 19:51 |
Lars Kiewidt
Rep Power: 16 |
Thank you! I knew about the subCycling but I was wondering whether there is some important meaning of the correctors. I have the paper, so I'll check it again.
Kind regards, Lars |
October 12, 2010, 08:31 |
compiling error
mohsen kh
Rep Power: 15 |
Hi every body,
I have a problem when I want to compile a model. the error is: ************************************************** ********************* ************************************************** ********************* viscoelasticLaws/mohsen/mohsen.C:159: error: no match for ‘operator==’ in ‘Foam:perator+(const Foam::tmp<Foam::fvMatrix<Type> >&, const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = Foam::SymmTensor<double>](((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >&)((const Foam::tmp<Foam::fvMatrix<Foam::SymmTensor<double> > >*)(& Foam::fvm::div(const Foam::surfaceScalarField&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::SymmTensor<double>](((Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))) == Foam:perator+(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::Tensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::dimensioned<double>&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator&(const Foam::tmp<Foam::GeometricField<TypeR, PatchField, GeoMesh> >&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Type1 = Foam::SymmTensor<double>, Type2 = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator-(const Foam::dimensioned<Type>&, const Foam::tmp<Foam::GeometricField<Type1, PatchField, GeoMesh> >&) [with Form = Foam::SymmTensor<double>, Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >&)((const Foam::tmp<Foam::GeometricField<Foam::SymmTensor<do uble>, Foam::fvPatchField, Foam::volMesh> >*)(& Foam:perator*(const Foam::scalar&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = Foam::SymmTensor<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>&)((const Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>*)(&((Foam::mohsen*)this)->Foam::mohsen::a_))))))))))))))))))))’ ************************************************** ************ ************************************************** ************ and the model is : // Velocity gradient tensor volTensorField L = fvc::grad( U() ); // Convected derivate term // volTensorField C = tau_ & L; // vorticity term volTensorField Vor = L - L.T(); // Twice the rate of deformation tensor volSymmTensorField twoD = twoSymm( L ); // fc scalar fc = 0.5; //1 - 27 * det( a_ ); //double dot term // volSymmTensorField mk = -( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ ); // Stress transport equation tmp<fvSymmTensorMatrix> aEqn ( fvm::ddt(a_) + fvm::div(phi(), a_) == ( 1 / 2 ) * ( Vor & a_ - a_ & Vor ) + ( 1 / 2 ) * keisi_ * ( twoD & a_ + a_ & twoD + 2 * ( ( (2 / 35) * ( 1 - fc ) * twoD - (2 / 7) * ( 1 - fc ) * ( a_ & twoD + twoD & a_ + (1 / 2) * tr( twoD & a_ ) * I_ ) - fc * tr( twoD & a_ ) * a_ ) ) + 2 * ci_ * twoD & ( I_ - 3 * a_ ) //+ twoSymm( C ) //- zeta_ / 2 * ( (tau_ & twoD) + (twoD & tau_) ) //- fvm::Sp( epsilon_ / etaP_ * tr(tau_) + 1/lambda_, tau_ ) ); aEqn().relax(); solve(aEqn); // Viscoelastic stress tau_ = (etaP_ / keisi_) * (a_ - I_); } ************************************************** **************** ************************************************** **************** where "a" , "tau" and "I" are symmetric tensors and "Vor" is asymmetric tensor. and the others are constant parameters. best |
March 25, 2023, 23:02 |
Shivam Padmani
Which paper ? can you share it's link to me? I also want to know about nAlphaSubCycles and all.
shivampadmani |
