Home > Forums > OpenFOAM Programming & Development
Topological mesh changes in parallel
Like Tree1Likes
  • 1 Post By hjasak
Old   November 27, 2009, 15:03
Default Topological mesh changes in parallel
Hrvoje Jasak
Dear All,
I had to do some work on topo changes in parallel and there is one IMPORTANT change required with the new svn update. Please pay attention - this WILL break your TOPO CHANGER code.
Due to a possibility that one CPU does do a topo change and another does not, I have introduced a dummy mapPolyMesh and synchronisation across CPUs to deal with it.
The OLD way of signalling no topo change was to put a null pointer inside of autoPtr<mapPolyMesh>
Thus: OLD VARIANT
autoPtr<mapPolyMesh> topoChangeMap = topoChanger_.changeMesh();
bool meshChanged = topoChangeMap.valid();
if (meshChanged)
etc.
Now, the pointer will never be NULL, but mapPolyMesh will carry thr information on whether the change happens. The new way of dealing with this is: NEW VARIANT
if (topoChangeMap->morphing())
Please keep this in mind: it is important in all cases of topo change.
I will change and keep alive all code components that are checked in; please revisit your local code and ask if there are problems.
Hrv
Hrvoje Jasak
Old   July 26, 2012, 08:52
Peter_600 is on a distinguished road
Dear Mr. Jasak,
I am having a problem with topochanger in parallel.
Please see here my problem: Engine Simulation in parallel
I am using layering for piston motion and tet automotion solver for the valve movement. For a single processor everything works nicely but in parallel it crashes as soon as a layer will be removed.
Best regards
Peter
Peter_600 is offline   Reply With Quote
Old   July 26, 2012, 09:03
Hrvoje Jasak
Yes, we have enabled topo changes in parallel about a year ago but there are guidelines and (minor) limitations on what you need to do. Further to that, you will need special domain decomposition and reconstruction tools that deal with parallelism under topo changes.
We currently deal with this under support contracts - please drop me a line and we can discuss what would be appropriate for you.
Hrvoje
hua1015 likes this.
Hrvoje Jasak
Thread Tools
Trackbacks are On
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 28, 2013 23:44
interDyMFoam, problems in mesh motion solutor run in parallel DLC OpenFOAM 11 December 11, 2012 03:20
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM 0 May 21, 2009 00:23
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
