Home > Forums > OpenFOAM Programming & Development
Setup of file U
Old   December 9, 2009, 03:48
Default Setup of file U
OFU
Jennifer
OFU is on a distinguished road
for my computations I need to precribe the velocity U by using simple functions for each of the three components (Ux, Uy, Uz). The functions should be applied to all six patches that are used and they look like following:
Ux = 2 + x^2
Uy = 2(z-x)y
Uz = 2 - z^2
To set these values to U I tried to write an application named setU, where the different functions are set to the three components of U. It did compile without giving an error message, but when I ran the applications the values were not set in U, so the file and the values did not change.
But for example when I describe U by the expression U=omega ^ mesh.C() with
dimensionedVector omega
"omega",
dimensionSet(0, 0, -1, 0, 0),
vector(0, 0, 1000)
and uncomment the three other lines, it works and the results of U = omega ^ mesh.C() are written to the six patches in the file U.
But I need to calculate the components of U by the given three functions, so can anyone tell me how it is possible to evaluate the function in each cell and then write the results to the file U?
----------------------------------- setU ------------------------------------------------------------------
#include "fvCFD.H"
int main(int argc, char *argv[])
# include "addTimeOptions.H"
# include "setRootCase.H"
# include "createTime.H"
// Get times list
instantList Times = runTime.times();
// set startTime and endTime depending on -time and -latestTime options
# include "checkTimeOptions.H"
runTime.setTime(Times[startTime], startTime);
# include "createMesh.H"
for (label i=startTime; i<endTime; i++)
runTime.setTime(Times[i], i);
Info<< "Time = " << runTime.timeName() << endl;
mesh.readUpdate();
# include "createFields.H"
//U = omega ^ mesh.C();
U.component(0) = 2 * factor + sqr(mesh.C().component(0));
U.component(1) = 2 * (mesh.C().component(2)-mesh.C().component(0)) * mesh.C().component(1);
U.component(2) = 2 * factor - sqr(mesh.C().component(2));
U.write();
Info<< "End\n" << endl;
return(0);
------------------------------------------------- U ------------------------------------------------------
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inside
type patch;
value uniform (0 0 0);
outside
type patch;
bottom
type patch;
top
type patch;
theta
type patch;
theta1
type patch;
OFU is offline   Reply With Quote
Old   December 10, 2009, 09:03
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Looking at Doxygen;
http://foam.sourceforge.net/doc/Doxy...tricField.html
it looks like component just returns a value and can't be overwritten. Use replace instead.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   December 11, 2009, 05:37
OFU
Jennifer
Thanks for your reply. Now it works...
Old   March 27, 2010, 11:59
Robertas N.
r08n is on a distinguished road
How to use 'replace' for scalar fields? E.g.,
volScalarField Q
IOobject
"Q",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Q.internalField()[mesh.findCell(point(0.01, 0.01, 0))].replace (0, 20.0);
produces this error:
icoTempFoam_src.C:80: error: request for member 'replace' in '((Foam::Field<double>*)Q.Foam::GeometricField<Typ e, PatchField, GeoMesh>::internalField [with Type = double, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]())->Foam::Field<double>::<anonymous>.Foam::List<doubl e>::<anonymous>.Foam::UList<T>:perator[] [with T = double](mesh.Foam::fvMesh::<anonymous>.Foam:olyMesh::<a nonymous>.Foam:rimitiveMesh::findCell(((const Foam:oint&)((const Foam:oint*)(& Foam::Vector<double>(((const double&)((const double*)(&1.00000000000000002081668171172168513294 309377670288085938e-2))), ((const double&)((const double*)(&1.00000000000000002081668171172168513294 309377670288085938e-2))), ((const double&)((const double*)(&0.0)))))))))', which is of non-class type 'double'
r08n is offline   Reply With Quote
Thread Tools
Trackbacks are On
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Changing the grid on the same set-up Katya FLUENT 12 October 8, 2009 16:31
FoamToVTK and MayaVi alexandrepereira OpenFOAM Post-Processing 57 August 11, 2008 04:15
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
