Ignition in reactingFoam
I'm following the Contrib_reactingFoam instructions from OpenFOAMWiki and i have a problem when i compile the changes with wmake. Here is what i see where in bold is what seem to be the problem: make: Warning: File `Make/linux64GccDPOpt/dontIncludeDeps' has modification time 3.3e+02 s in the future Making dependency list for source file reactingFoam.C make: warning: Clock skew detected. Your build may be incomplete. make: Warning: File `reactingFoam.dep' has modification time 3.3e+02 s in the future SOURCE=reactingFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I../XiFoam -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/reactionThermo/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/basic/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/ODE/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/engine/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/reactingFoam.o In file included from reactingFoam.C:80: ignite.H: In function int main(int, char**): ignite.H:11: error: invalid types <unresolved overloaded function type>[Foam::label] for array subscript Can someone help me with this? From the instructions, it says to include ignition after the multivariateScheme and it is written ignition.H, should it be ignite.H?? If i do that, i get the following error when compiling: In file included from reactingFoam.C:39: ignite.H:1: error: expected unqualified-id before if I'm not sure of what to do with that. Thanks |
Yes, actually, I got the same problem while trying to compile the changed case.
Hope anyone can help. |
A possible way of solving this problem
According to the error message, it seems the temperature field T is not recognized by the program.Thus, I added the following lines in the createFields.H file after line 24. The error message was gone after I did this. volScalarField T ( IOobject ( "T", runTime.timeName(), mesh ), thermo.T() ); I can get my program run using the new solver. I am also new to OpenFOAM and am not sure if this is valid. Just an idea. Xinyu |
Ms.
type hs instead of h !! it will compile
Hi
I have a doubt, how can i compile the code? What i have to do? |
