-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Is neighbourFieldName used for solids in chtMultiRegionFoam? (http://www.cfd-online.com/Forums/openfoam-programming-development/73759-neighbourfieldname-used-solids-chtmultiregionfoam.html)
Niklas Järvstråt March 16, 2010 09:26
Hi!
When I set a bad name in a fluid changeDictionary, I get an error message of the type:
--> FOAM FATAL ERROR:
request for volScalarField Thisiswrong from objectRegistry wire failed
available objects of type volScalarField are
7
cp
K
rho
sigma
T
rhosCps
Vel
Which is fine, of course. :)
However, doing the same in a solid region gives no error message whatsoever and the calculation proceeds as if nothing is wrong. Is this because the neighbor name of solids is hardcoded somehow, or what happens here?
(I need to know because I try to adapt solidWallMixedTemperatureCoupled for use not with temperature but with voltage)
