Is neighbourFieldName used for solids in chtMultiRegionFoam?
Old   March 16, 2010, 08:26
Default Is neighbourFieldName used for solids in chtMultiRegionFoam?
Niklas Järvstråt
Niklas Järvstråt is on a distinguished road
Hi!
When I set a bad name in a fluid changeDictionary, I get an error message of the type:
--> FOAM FATAL ERROR:
request for volScalarField Thisiswrong from objectRegistry wire failed
available objects of type volScalarField are
7
cp
K
rho
sigma
T
rhosCps
Vel
Which is fine, of course.
However, doing the same in a solid region gives no error message whatsoever and the calculation proceeds as if nothing is wrong. Is this because the neighbor name of solids is hardcoded somehow, or what happens here?
(I need to know because I try to adapt solidWallMixedTemperatureCoupled for use not with temperature but with voltage)
Niklas Järvstråt is offline   Reply With Quote
Problem with running chtMultiRegionFoam after using setSet utility Victor OpenFOAM 12 March 24, 2023 00:01
How can I do a solidWallMixedVoltageCoupled patch in chtMultiRegionFoam? Niklas Järvstråt OpenFOAM Programming & Development 2 April 1, 2010 05:22
chtMultiregionFoam msarkar OpenFOAM 21 February 10, 2010 23:12
chtMultiRegionFOAM " Heattransfert" ronaldo OpenFOAM 1 January 1, 2010 10:08
problems with probes() function in chtMultiRegionFoam Victor OpenFOAM 0 November 25, 2009 15:08
