temperature equation for one phase in multiphase solver
Old   April 13, 2010, 05:06
Default temperature equation for one phase in multiphase solver
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I have been working with the interPhaseChangeFoam solver for a while now, and have started writing a phase change model based on temperature. Right now the temperature is still given via the dictionary input.
I wanted to add the energy equation for the fluid phase to this solver. The governing equation is
which I tried implementing like this
//    const volScalarField rhoAlpha = cp * rho1 * alpha1; // for time derivative
        "rhoAlpha",
        cp * rho1 * alpha1
    surfaceScalarField phiAlpha
        "phiAlpha",
        phi * rho1 * cp  * fvc::interpolate(alpha1) //check with rhoPhi from the alphaEqn.H file
//        rhoPhi * cp //* fvc::interpolate(alpha1)
    volScalarField lambdaFAlpha
        "lambdaFAlpha",
        lambdaF * alpha1
    Pair<tmp<volScalarField> > mDotAlphal = twoPhaseProperties->mDotAlphal();
    const volScalarField mDotAlphac = mDotAlphal[0]();
    fvScalarMatrix TEqn
          fvm::ddt(rhoAlpha,T)
        + fvm::div(phiAlpha, T)
        - fvm::laplacian(lambdaFAlpha, T)
       == mDotAlphac * ifg
    TEqn.relax();
    TEqn.solve();
    Info << "Max(T): " << max(T).value() << " K "
    << "Min(T): " << min(T).value() << " K" << endl;
Unfortunately, I have had no success in actually using this within the solver, the results are completely bogus. One thing that is obvious is that there might be a problem with the alpha1 attachment to the equation.
My first thought was to maybe be able to extract the mesh that contains water alpha1>0, and impose boundary conditions onto the interface cells. Is there a way to do it, or does somebody else see what could be wrong with the implementation of this equation?
~roman
romant is offline   Reply With Quote
Transport Equation for temperature variance ameya OpenFOAM Running, Solving & CFD 0 December 5, 2008 01:16
how to active Temperature equation in FLUENT james FLUENT 5 July 18, 2006 02:01
how to active temperature equation james FLUENT 0 June 19, 2006 03:54
multiphase UDF, variables for phase velocities Kerem FLUENT 4 March 27, 2006 08:20
2 phase flow equation in 1D Nicolas Main CFD Forum 0 December 13, 2003 14:19
