Self-defined IOobject variable not in objectRegistry
Old   April 16, 2010, 07:06
Default Self-defined IOobject variable not in objectRegistry
Patrick Dems
lama is on a distinguished road
I have implemented two new variables of the same kind as
volScalarField m0
IOobject
    "m0",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
and
volScalarField m1
    IOobject
        "m1",
        runTime.timeName(),
        mesh,
    mesh
m0 will be only overwritten during the simulation but for m1 a kind of continuity equation is solved with relax() and solve()
The problem now is that m1 is not in the regObjects list but m0. Therefore I have problems with runtime.write() where m1 won't be written and with fieldAverage, because fieldAverage doesn't know m1:
Calculating averages
    request for volScalarField m1 from objectRegistry region0 failed
    available objects of type volScalarField are
The curious thing is, that on one cluster it works and on another one not.
At the second cluster the code is vectorized during the compilation.
I have no idea, can anybody help me, at least some hints how to force m1 into the objectRegistry?
Thanks in advance!
lama is offline   Reply With Quote
Old   April 20, 2010, 06:49
Default Problem gone by changing from version 1.5 to 1.6
Patrick Dems
Don't know why but using version 1.6 it works. That's what I call good work in software improvement!
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
