Adding a new temperature dependent viscositymodel? |
May 6, 2010, 04:56 |
Dan Gadensgaard
Rep Power: 15 |
Hi Foamers.
I am currently trying to implement a new viscosity model that is dependent on temperature. I can see that a few others in this forum has succesfully implemented the CrossWLF model, but i have not yet seen how they have done it. My problem is how to read the volScalarField T that i have for temperature, created in createFields.H and calculated with a temperature equation. Whenever i do this, it messes up in several classes, because the viscositymodel suddenly have an extra parameter T besides U and phi. Does anyone have a way to get around this? or maybe even a working code to do this? // Dan |
May 8, 2010, 13:30 |
Solved
Dan Gadensgaard
Rep Power: 15 |
Hi again.
There is no need to answer, as i have just solved this issue. However, i did in a somewhat alternative way, by adding the volScalarField T to all my transportmodels. It works, but it is not the most elegant solution . // Dan |
May 12, 2010, 18:53 |
Johannes Baumann
Rep Power: 17 |
Hi Dan,
I came across your thread just recently so I missed answering in time... A few months ago I was in the same situation, searching for a CrossWLF viscosity model for OpenFOAM. Since I couldn't find any working code snippets floating around on the forum, I tried to implement it myself. I don't know exactly if everything is implementet correctly, since I encountered some serious stability problems with increasing viscosity and VOF solvers. However, maybe at least I can provide you with a 'more elegant' solution for your problem. Assuming you already added volScalarField T to your CrossWLF class, you should be able to read it during the viscosity correction calcNu() using Code:
const volScalarField& T = U_.mesh().lookupObject<volScalarField>("T"); Best regards, Johannes |
May 13, 2010, 03:32 |
Dan Gadensgaard
Rep Power: 15 |
Hi Johannes.
Thanks you for your answer. The code for accessing "T" in the models class you've provided is definetly more elegant, as iv'e implemented it by adding "volScalarField T" to all the constructors in the transportmodels. As for the testcase, i am validating my implementation against the article: S. Radl, T. Tritthart, J.G. Khinast: "A Novel Design for hot-melt extrusion pelletizers", brought in Chemical Engineering Science, by Elsevier. In this article they have also use OpenFOAM, and they have shown the development of flow and temperature through a capillary die hole. Note that I have not implemented the CrossWLF model, but instead added an exponential term to the powerLawModel. Best Regards, Dan |
May 13, 2010, 07:39 |
Laurence R. McGlashan
Rep Power: 23 |
Is that really more elegant though? If you're looking for better programming practice then it is surely preferable to pass temperature through the constructor, as opposed to looking the temperature up in the object registry. Or you could just pass it through a new member function when you want to evaluate a new viscosity.
Laurence R. McGlashan :: Website |
May 13, 2010, 08:32 |
Dan Gadensgaard
Rep Power: 15 |
Well, i see your point, but passing it through the constructor is in my opinion only an elegant solution if it done consistenly throughout the code, which requires a respectible amount of work. This will also result in the volScalarField T being added to many classes, without ever being used.
I am sure that you could pass it through a new member function, but being on the "beginner"-level in OpenFOAM, this will take me a considerable amount of time to do. // Dan |
May 13, 2010, 08:53 |
Rep Power: 23 |
I would have a look at how the thermophysical models are implemented, in particular how the basic/psiThermo and basic/rhoThermo inherit from basicThermo.
Obviously, it may not be worth the effort, but it may be quite satisfying to try!
May 19, 2010, 05:58 |
problem with adding a viscosityModel
xianghong wu
Rep Power: 16 |
Hi, foamers,
I am adding a viscosityModel into OF. I set up a folder named myViscosityModel into viscosityModels folder, looks like PowerLaw. Surely I set up myViscosityModel.C and myViscosityModel.H. when I finished these I compile it with command "wmake libso". there comes an error in the results: "myViscosityModelCoeffs_lookup" was not declared in this scope. the myViscosityModel.C file is as follows: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 1991-2008 OpenCFD Ltd. \\/ M anipulation | ------------------------------------------------------------------------------- \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "myViscosityModel.H" #include "addToRunTimeSelectionTable.H" #include "surfaceFields.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace viscosityModels { defineTypeNameAndDebug(myViscosityModel, 0); addToRunTimeSelectionTable ( viscosityModel, myViscosityModel, dictionary ); } } // * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * * // Foam::tmp<Foam::volScalarField> Foam::viscosityModels::myViscosityModel::calcNu() const { //shearrate //- in your class, we can obtain the temperature. The only possible way is looking up "T" through objectRgistry. const volScalarField & T=U_.db().lookupObject<volScalarField>("T"); volScalarField shearrate=max(minshearrate_,sqrt(2.0*((symm(fvc::g rad(U_))) && (symm(fvc::grad(U_))))/3.0)); //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷 volScalarField Z=shearrate*(exp(deltaH_/(R_*T))); return asinh(pow(Z/A_,1.0/n_))/(3*beta_*shearrate)/rho_; } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::viscosityModels::myViscosityModel::myViscosi tyModel ( const word& name, const dictionary& viscosityProperties, const volVectorField& U_, //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷 const surfaceScalarField& phi ) : viscosityModel(name, viscosityProperties, U_, phi), //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷 myViscosityModelCoeffs_(viscosityProperties.subDic t(typeName + "Coeffs")), //********what is this for??? rho_(myViscosityModelCoeffs_.lookup("rho")), R_(myViscosityModelCoeffs_.lookup("R")), A_(myViscosityModelCoeffs_.lookup("A")), beta_(myViscosityModelCoeffs_.lookup("beta")), deltaH_(myViscosityModelCoeffs_.lookup("deltaH")), n_(myViscosityModelCoeffs_.lookup("n")), minshearrate_(myViscosityModelCoeffs_.lookup("mins hearrate")), nu_ ( IOobject ( name, U_.time().timeName(), //锟斤拷锟斤拷锟截凤拷锟斤拷U原锟斤拷没锟斤拷锟铰伙拷锟斤拷 U_.db(), IOobject::NO_READ, IOobject::AUTO_WRITE ), calcNu() ) {} // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // bool Foam::viscosityModels::myViscosityModel::read ( const dictionary& viscosityProperties ) { viscosityModel::read(viscosityProperties); myViscosityModelCoeffs_ = viscosityProperties.subDict(typeName + "Coeffs"); myViscosityModelCoeffs_.lookup("rho") >> rho_; myViscosityModelCoeffs_.lookup("R") >> R_; myViscosityModelCoeffs_.lookup("A") >> A_; myViscosityModelCoeffs_.lookup("beta") >> beta_; myViscosityModelCoeffs_.lookup("deltaH") >> deltaH_; myViscosityModelCoeffs_.lookup("n") >> n_; myViscosityModelCoeffs_lookup("minshearrate")>>min shearrate_; return true; } // ************************************************** ********************* // the error is located at the last line: myViscosityModelCoeffs_lookup)"minshearrate")>>min shearrate_; Anybody knows the reason? Thanks in advance. Wendy |
May 19, 2010, 06:00 |
myviscosityModel.H
#9 |
xianghong wu
Rep Power: 16 |
here is the File "myViscosityModel.H"
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 1991-2008 OpenCFD Ltd. \\/ M anipulation | ------------------------------------------------------------------------------- Class Foam::viscosityModels::myViscosityModel Description Standard viscoPlastic non-Newtonian viscosity model. SourceFiles myViscosityModel.C \*---------------------------------------------------------------------------*/ #ifndef myViscosityModel_H #define myViscosityModel_H #include "viscosityModel.H" #include "dimensionedScalar.H" #include "volFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { namespace viscosityModels { /*---------------------------------------------------------------------------*\ Class myViscosityModel Declaration \*---------------------------------------------------------------------------*/ class myViscosityModel : public viscosityModel { // Private data dictionary myViscosityModelCoeffs_; // dimensionedScalar k_; // dimensionedScalar n_; // dimensionedScalar nuMin_; // dimensionedScalar nuMax_; // volScalarField shearrate_; // volScalarField Z_; dimensionedScalar rho_; dimensionedScalar R_; dimensionedScalar A_; dimensionedScalar beta_; dimensionedScalar deltaH_; dimensionedScalar n_; volScalarField nu_; dimensionedScalar minshearrate_; // Private Member Functions //- Calculate and return the laminar viscosity tmp<volScalarField> calcNu() const; public: //- Runtime type information TypeName("myViscosityModel"); // Constructors //- Construct from components myViscosityModel ( const word& name, const dictionary& viscosityProperties, const volVectorField& U, const surfaceScalarField& phi ); // Destructor ~myViscosityModel() {} // Member Functions //- Return the laminar viscosity tmp<volScalarField> nu() const { return nu_; } //- Correct the laminar viscosity void correct() { nu_ = calcNu(); } //- Read transportProperties dictionary bool read(const dictionary& viscosityProperties); }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace viscosityModels } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************** *********************** // Thanks, Wendy |
May 19, 2010, 06:04 |
#10 | |
Rep Power: 23 |
myViscosityModelCoeffs_.lookup("minshearrate")>>mi nshearrate_; You should also start another thread as this doesn't really relate to what was being discussed earlier.
May 22, 2010, 06:47 |
#11 |
xianghong wu
Rep Power: 16 |
Laurence,
Thank you so much. Sorry for being so careless. Wendy |
temperature, viscosity models |
Display Modes | |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Temperature Dependent Fluid Properties | eliwide | OpenFOAM Running, Solving & CFD | 4 | December 15, 2012 20:21 |
Poor convergence with temperature dependent density on modified pisoFOAM | ovie | OpenFOAM | 1 | March 20, 2011 04:19 |
Multicomponent with Temperature dependent | SAKTI | Siemens | 3 | September 15, 2008 23:09 |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 02:22 |
