runtime error after succ. compilation + vector component division
Old   May 22, 2011, 10:12
Default runtime error after succ. compilation + vector component division
ramhari is on a distinguished road
I have a problem in running after successfully compiling the modified rhoCentralFoam code.
volVectorField rhoU_dummy = rhoU_old;
volScalarField q_2 = ( rhoU.component(vector::X) - rhoU_dummy.component(vector::X) ) / rhoU_dummy.component(vector::X) );
compiles well. But when it runs immediately shows "floating point exception" error.
The denominator going zero may be one of the reason. I tried even tried adding 1e-06 to it. It compiles well but throws away the same error during run time.
may be my vector component division goes wrong?
Can anyone help me please : )
ramhari is offline   Reply With Quote
Old   May 25, 2011, 11:08
David Gaden
marupio is on a distinguished road
You could try using the stabilise function on the denominator. Also, try adding log lines just prior to the equation, so you can see what values are going into it.
marupio is offline   Reply With Quote
Old   May 26, 2011, 01:18
The velocity vector is initially set zero. I think by adding some 1e-06 to it before division should not show any problem. The floating point exception error shows at the
second iteration itself.
Old   May 26, 2011, 08:37
David Gaden
The stabilize function will add a small amount to the number if it is close to zero.
Old   May 28, 2011, 15:53
Dear marupio,
I am sorry that i m not getting clearly of what u mean by stabilise function. Can u pls post something of that sort!
Old   May 28, 2011, 16:01
David Gaden
Sorry, the function is stabilise(scalar value, scalar smallAmount).
I was wrong - it doesn't check if it is close to zero, it always adds the smallAmount. But, it will add it in the right direction (positive or negative).
Here's how you'd use it:
volScalarField q_2 = ( rhoU.component(vector::X) - rhoU_dummy.component(vector::X) ) / stabilise(rhoU_dummy.component(vector::X), SMALL) );
Old   May 30, 2011, 06:40
Thanks marupio,
division, exception, floating, point, vector
