Lagrangian Particle Tacking
1 Attachment(s)
Dear FOAMers:
Rencetly, I am implementing a particle-particle collision model into lagrange/intermediate/. When I test a case for tracking a lot of particles at different diameter sizes, which of some are the biger than the grid size, I find the small particles are not beyond the boundary, it is right, but the biger ones have strange behavour, particle sphere border will cross the mesh boundary. I want to known whether the track algorithm has limit to require particle size smaller than mesh size or somewhere exist a bug. I will be very glad if I know your suggestions for solving this problem. Best regards Nording |
Hi Nording,
You are correct, the particle code only checks for intersections in the particle's current cell. If the particle is larger than the cell-size (approximately) then the particle can 'miss' the surface, while still being less than it's radius away. As for overcoming this, I am not sure - we are planning to tackle it by using a distance field, or something similar, to check for impact. At the moment it's not a problem for us (small particles), so we haven't gone very far along this approach. I would be interested to know how you are implementing the collision mechanics/tests however. Cheers Andrew |
