curvature correction term, material derivative of a tensor
Old   April 1, 2010, 10:08
Default curvature correction term, material derivative of a tensor
Volker Tritschler
volker is on a distinguished road
I'm planning to implement a curvature correction term to an explicit algebraic reynolds stress model based on the existing k-e-model of Launder and Sharma in order to sensitize the Launder-Sharma-model to streamline curvature.
The curvature correction term is to be implemented according to P.E. Smirnov and F.R. Menter "Sensitization of the SST Turbulence Model to Rotation and Curvature by Applying the Spalart-Shur Correction Term".
I ran into problems quite fast. There is a term, which is the material derivative of the shear strain tensor. The implementation is not straight-forward, especially in tensor notation. Either one has somehow to implement a summing over all faces of a control volume or to evaluate the gradient of the shear strain tensor, which leads to a tensor of third order. And right now, I do not see a way to get rid of this problem.
Does anyone has already tried to implement a curvature correction or has any experience on that? Or even know how to implement a material derivative of a tensor?
I'm glad for any hint.
Greets, volker
volker is offline   Reply With Quote
Old   April 1, 2010, 10:46
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
I have try RC correction as you mentioned in ref paper. you can send me a mail. if interesting.
my email address: waynezw0618@163.com
waynezw0618 is offline   Reply With Quote
Old   May 6, 2010, 15:55
Default Gradient of a second order tensor
Michael B Martell Jr
theory37 is on a distinguished road
I am attempting to add a term to a Reynolds stress transport model which involves taking the gradient of the Reynolds stress tensor, which should result in a tensor of rank three.
Even a simple attempt fails:
volTensorField test = fvc::grad(R);
(If I attempt to take the gradient of a non-symmetric tensor, I still cannot compile.) In both cases, the result is the same:
error: no type named ‘type’ in ‘class Foam::typeOfRank<double, 3>’
error: no matching function for call to 'grad(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&)’
Is it possible to take the gradient of a second order tensor in FOAM?
Any ideas or help would be appreciated!
theory37 is offline   Reply With Quote
Old   May 6, 2010, 16:55
Volker Tritschler
hi michael,
I had exactly the same problem, though I found it kind of surprising because OpenFOAM is supposed to handle tensors of rank three.
But the gradient seems to be restricted to tensors of rank one. I hope that there might be a workaround.
hope someone can help us.
cheers, volker
Old   May 6, 2010, 17:03
Hi Volker. I have discussed this problem with some of my colleagues here and we agree that this would be non-trivial to implement. I am going to try, and I'll keep you posted on my progress. Feel free to contact me through http://www.ecs.umass.edu/~mmartell if you'd like.
FYI, I have tried not assigning the gradient to a particular type by simple putting
fvc::grad(R);
to see if I could figure out what type FOAM was looking for. No luck.
Cheers,
Mike
Old   May 7, 2010, 07:29
Volker Tritschler
would be great, if you would come up with something new.
keep me posted!
Old   May 27, 2010, 03:50
Volker Tritschler
hi michael,
did you manage to implement the gradient of a tensor?
cheers, volker
Old   June 3, 2010, 08:08
Hi Volker,
I managed to do what I needed "by hand" but it is sloppy and not generic. I'll attach the source for it. It has no external dependencies (you can ignore the inclusion of OEC.H) and it doesn't need to be cast in the incompressible or RASModels name space - I simply took it right from my existing code.
In my case, I needed something like fvc::grad(kINT) & fvc::grad(RINT) with kINT being a volScalarField and RINT being a volSymmTensorField. Note that this inner product (of grad(kINT), a vector, and grad(RINT), a rank 3 tensor) results in a rank 2 symmetric tensor. I know this isn't exactly what you were looking for, but the structure is there.
Let me know if you need any help
Mike
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Curvature Correction & Reattachment Mod. Felix CFX 5 December 19, 2010 16:04
How to use SST Curvature Correction mike wilson CFX 11 December 19, 2010 16:04
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
