June 17, 2010, 20:41 |
Problem with log(scalar) operator
Pascal
Rep Power: 16 |
Hi all,
I try to use the log(scalar) operation in pre processing utility but I have the following error message: Code:
~/OpenFOAM/ag74290-1.6.x/applications/utilities/preProcessing/vit_cond_init_4t_rand$ wmake SOURCE=vit_cond_init_4t_rand.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/vit_cond_init_4t_rand.o vit_cond_init_4t_rand.C: In function ‘int main(int, char**)’: vit_cond_init_4t_rand.C:108: error: call of overloaded ‘log(Foam::scalar&)’ is ambiguous /usr/include/bits/mathcalls.h:110: note: candidates are: double log(double) /home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/dimensionedScalar.H:74: note: Foam::dimensionedScalar Foam::log(const Foam::dimensionedScalar&) /home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Scalar.H:236: note: Foam::doubleScalar Foam::log(Foam::doubleScalar) /home/ag74290/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Scalar.H:236: note: Foam::floatScalar Foam::log(Foam::floatScalar) make: *** [Make/linux64GccDPOpt/vit_cond_init_4t_rand.o] Error 1 Any advice? Pascal |
June 18, 2010, 01:01 |
Martin
Rep Power: 21 |
Hello Pascal,
you may try it this way: scalar logTest = Foam::log(scalar(42)); Martin |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
problem with using colocated code | Jack | Main CFD Forum | 0 | December 15, 2002 00:15 |
