Problem with refCast in parallel
Old   July 14, 2010, 12:50
Default Problem with refCast in parallel
Michael
Mick is on a distinguished road
Hi all,
I am having a problem with a bit of code in parallel. When I run it serially, there are no warnings but when I run it in parallel I get warnings. It doesn't stop my case from running, but it creates massive log files when I'm running across a few processors. If anybody has any idea as to the source of this warning and how to rectify it I'd appreciate it.
Please find below my piece of code and then a piece of the log file showing the warnings.
Info<< "Time: " << runTime.timeName()
<< "\nI am in the updateTractions file" << endl;
tractionDisplacementIncrementFvPatchVectorField& loadingPatchDU3 =
refCast<tractionDisplacementIncrementFvPatchVector Field>
DU.boundaryField()[loadingPatchID3]
tractionDisplacementIncrementFvPatchVectorField& loadingPatchDU2 =
DU.boundaryField()[loadingPatchID2]
Info<< "loadingPatchDU3(a.k.a. traction3).DTraction Before= " << loadingPatchDU3.DTraction() << endl;
Info<< "loadingPatchDU2(a.k.a. traction2).DTraction Before= " << loadingPatchDU2.DTraction() << endl;
Snippet of log file:
[3] --> FOAM Warning :
[3] From function max(const UList<Type>&)
[3] in file /gpfs/mech/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/FieldFunctions.C at line 322
[3] empty field, returning zero
[2] --> FOAM Warning :
[2] From function max(const UList<Type>&)
[4] --> FOAM Warning :
[5] --> FOAM Warning :
[5] From function max(const UList<Type>&)
[5] in file /gpfs/mech/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude/FieldFunctions.C at line 322
[5] empty field, returning zero
loadingPatchDU3(a.k.a. traction3).DTraction Before= 149{(0 0 1000)}
loadingPatchDU2(a.k.a. traction2).DTraction Before= 94{(0 1000 0)}
Thanks in advance,
Michael
Mick is offline   Reply With Quote
problem with parallel computation Jinhwi, Lee Siemens 0 January 20, 2009 02:23
problem with parallel system tahere FLUENT 2 December 27, 2008 18:44
star cd 4.06 parallel problem whitemelon Siemens 3 October 23, 2008 14:42
cfx4 parallel sover Problem!! HELP Richard.A CFX 2 August 3, 2002 03:54
Parallel computation problem in Tascflow dandy CFX 3 April 21, 2002 00:32
