I want to the velocity vector for the first node point to the wall. Can I use wallDis
Old   January 13, 2012, 08:25
Default I want to the velocity vector for the first node point to the wall. Can I use wallDis
Gregory
catapult is on a distinguished road
Hi there
I have a particle P(xp,yp,zp) somewhere in the mesh. I need the index of the nearest wall cell to my point P so I can calculate the velocity vector of the first node point to the wall. I first thought of using the library "wallDist.H". It unfortunately only returns the distance of the closest cell at the wall and not the index of this latter.
in other words:
//create field containg wall distances
volScalarField wd = wallDist(mesh)
//create field of the indexes of the closest wall cells
volField<label> = wd.labelOfTheWallCells() <- how do I get this?
Is there any such functions already implemented in OF? If not, what could I do to achieve this ?
Thanks
catapult is offline   Reply With Quote
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 07:22
Velocity and Temp. jump on wall p_agoodboy FLUENT 0 March 27, 2011 21:53
how to calculate flow properties along the first grid point near to the wall kiran OpenFOAM Post-Processing 2 September 12, 2010 12:59
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
