Home > Forums > OpenFOAM Programming & Development
Adding U*U as a source term
Old   August 30, 2010, 16:45
Default Adding U*U as a source term
Ozgur Kirlangic
ozgur is on a distinguished road
Hi Foamers,
I am trying to solve the following equation:
dU/dt = grad(p) - 0.5*(f/L)*(U*U)
here, U(velocity vector), p (pressure), and L is length, (f is dimensionless scalar).
In fact, I made an attempt and it seems working for 1D .. However, I can not be very sure about the approach that I use (especially for 2D and 3D problems), and I need some comments from more experienced people.
I constructed my equations as follows:
        vector identity(1,1,1);
        volVectorField gradp = fvc::grad(p);
        fvVectorMatrix UEqn
         	fvm::ddt(U) + fvm::Sp((U & identity)/2*(1/L+f/D), U)
        solve(UEqn == -fvc::grad(p));
The reason that I am not sure is about the term "U*U" in the original equation. Since U is a vector, U*U will produce a matrix, and therefore it was not possible to write "U*U" as it is to the code as a source term.
Instead, assuming that only the i component of the vectors will be used while solving Ux, I wrote "U & identity" to obtain the value of the x component of U and put it in to the first parameter place of Sp function.
This works for 1D but I cannot be sure about my assumption about the behavior of U & identity expression in 2D and 3D problems..
In short, say that U(1, 2, 3) then will "U & identity" produce 1+2+3=6 in ALL Ux, Uy and Uz solutions OR will it produce 1 in Ux solution, 2 in Uy solution and 3 in Uz solution??
Kind regards,
Ozgur
ozgur is offline   Reply With Quote
Old   August 31, 2010, 11:05
Ozgur Kirlangic
PS: The above is not a realistic CFD problem, but I am just playing a little with the code so to get some understanding...
Anyway, I think I got the answer of my question by constructing a 2D case. And, I saw that unfortunately (in fact fortunately) my assumption was wrong, i.e. use of "U & identity" produced Ux+Uy+Uz.
So, in this problem, what is needed is something like scale(U,U) function, which gives the product of corresponding components of vectors U and U; so it will produce another vector (not a matrix which only the main diagonal is useful).
I couldn't still make scale(U,U) work. But asked about it under another title.
Ozgur
Old   July 20, 2011, 11:22
Amin
AcfdO is on a distinguished road
scale(U,U) doesn't work and unfortunately it has not been updated in programmers guide. You should use cmptMultiply(U,U) instead.
AcfdO is offline   Reply With Quote
Thread Tools
Trackbacks are On
momentum source term zwdi FLUENT 13 December 5, 2013 18:58
Adding volumetric Source Term mohanamuraly OpenFOAM 0 May 17, 2009 22:00
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Adding a momentum source term segersson OpenFOAM Running, Solving & CFD 5 March 3, 2006 00:06
