For loops in OpenFoam
Old   September 6, 2010, 07:44
Default For loops in OpenFoam
Balkrishna Patankar
balkrishna is on a distinguished road
I am generalising the twoPhase Euler Foam to handle n Phases . In the file pEqn.H I want to sum up the phase fraction of all the dispersed phases to get the dispersed phase . To do so I programmed the following :
 PtrList<surfaceScalarField>alphaf(nPhases);
    //just an initialization
    surfaceScalarField af ;
    surfaceScalarField betaf = scalar(1) - af;
    forAll(alphaf,aPh)
        alphaf.set(aPh,fvc::interpolate(phases[aPh].alpha()));
        af= af + alphaf[aPh];
    betaf = scalar(1) - af ;
On compilation I got the following error :
error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricField()’
/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:652: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::wordList&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh]
balkrishna is offline   Reply With Quote
Old   September 6, 2010, 16:46
David Gaden
marupio is on a distinguished road
The problem isn't the for loop, it's your PtrList .set command:
You have to create a GeometricField on the freestore for this pointer list... and you have to use a proper GeometricField constructor.
alphaf.set
    aPh,
    new surfaceScalarField
        IOobject
            // IOobject constructor parameters - you decide
        mesh,
Hope that helps!
marupio is offline   Reply With Quote
Old   September 7, 2010, 00:37
Balkrishna Patankar
The error wasnt for the alphaf.set line . It was for the "surfaceScalarField alphaf ; " line
Old   September 7, 2010, 04:06
akidess's Avatar
Anton Kidess
Duplicate: http://www.cfd-online.com/Forums/ope...-openfoam.html
Old   September 7, 2010, 11:54
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
there is no default constructor for the surfaceScalarField.
it needs to know about its size, take any available surfaceScalarField available and use that.
For instance phi and
surfaceScalarField alphaf(phi.size());
niklas is offline   Reply With Quote
Old   September 7, 2010, 12:01
Balkrishna Patankar
Thanks evry1 .... my problem was solved ... i initialized af in createFields.H and that solved the problem as suggested by alberto here ...
error, multiphase flow
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
