-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   For loops in OpenFoam (http://www.cfd-online.com/Forums/openfoam-programming-development/79839-loops-openfoam.html)
balkrishna September 6, 2010 07:44
I am generalising the twoPhase Euler Foam to handle n Phases . In the file pEqn.H I want to sum up the phase fraction of all the dispersed phases to get the dispersed phase . To do so I programmed the following :
PtrList<surfaceScalarField>alphaf(nPhases);
    //just an initialization
    surfaceScalarField af ;
    surfaceScalarField betaf = scalar(1) - af;
    forAll(alphaf,aPh)
        alphaf.set(aPh,fvc::interpolate(phases[aPh].alpha()));
        af= af + alphaf[aPh];
    betaf = scalar(1) - af ;
On compilation I got the following error :
error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::GeometricField()’
/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/GeometricField.C:652: note: candidates are: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::wordList&) [with Type = double, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh]
marupio September 6, 2010 16:46
The problem isn't the for loop, it's your PtrList .set command:
You have to create a GeometricField on the freestore for this pointer list... and you have to use a proper GeometricField constructor.
alphaf.set
    aPh,
    new surfaceScalarField
        IOobject
            // IOobject constructor parameters - you decide
        mesh,
Hope that helps!
balkrishna September 7, 2010 00:37
The error wasnt for the alphaf.set line . It was for the "surfaceScalarField alphaf ; " line
akidess September 7, 2010 04:06
Duplicate: http://www.cfd-online.com/Forums/ope...-openfoam.html
niklas September 7, 2010 11:54
there is no default constructor for the surfaceScalarField.
it needs to know about its size, take any available surfaceScalarField available and use that.
For instance phi and
surfaceScalarField alphaf(phi.size());
balkrishna September 7, 2010 12:01
Thanks evry1 .... my problem was solved ... i initialized af in createFields.H and that solved the problem as suggested by alberto here ...
