-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   add entry to wordList (http://www.cfd-online.com/Forums/openfoam-programming-development/80329-add-entry-wordlist.html)
peterwy September 22, 2010 12:03
I've a probably very easy question, but I tried already a lot - nearly the cpl. afternoon - but nothing worked so far.
First I used something like vector<std::string> and here I added strings with the command vector.push_back(....)
Now I want to use the std foam syntax
I created a wordList what should be nearly the same as vector<std::string>
To add elements at the end the .append function should work.
But now the problems comes by:
I can append only another wordList but I'm not able to append a entry like
wordList testList;
testList.append("the first entry");
testList.append("next entry");
and so far.
Is anybody able to help me? Would be greatful.
Thx a lot, bye
Peter
olesen September 24, 2010 02:44
wordList testList;
and so far.
1. a "word" has no spaces, so in your example you really want a list of "string", where "string" is actually Foam::string and not std::string.
2. If you are doing several appends, using "List" is very inefficient.
A "List" is normally used with pre-allocated space.
For example,
    // dimension for exactly 2 items
    List<string> testList(2);
    testList[0] = "the first entry";
    testList[1] = "next entry";
If you want many appends, you should use a DynamicList.
For example,
    // reserve at least 10 spaces
    DynamicList<string> testList(10);
    testList.append("yet another entry");
Take a look at "applications/test/DynamicList/DynamicListTest.C" for some more ideas ... the DynamicList has lots of functionality.
Note that if you have a list of bool values, you should consider using PackedBoolList - it has many pleasant features that make it behave somewhat like a DynamicList.
peterwy September 24, 2010 03:00
Thx already now for your reply. Some time ago I worked with those dynamic Lists. I will try what's possible in this case. I will come back to this threat then in the next days because at the moment other project work is urgent.
Thx & have a nice weekend
Peter
peterwy October 4, 2010 07:13
SOLVED
working with those dynamic lists is exactly what I needed because when using vector OF has problems with other include files.
Thx @ all, Best Regards, Peter
