applyConstraintsAndThermostats
Dear all
i in OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule at line 1158 we have the constrains and thermostats, yet i cant figure out if this member function is working or not, here it is the function HTML Code:
void Foam::moleculeCloud::applyConstraintsAndThermostats Thanks |
You mean the Info statements? Are you running it in parallel or in serial?
Yes i exactly mean the Info statement, i tried in both serial and parralel, no diffrence.
It won't be called then.
If you run in parallel, I think Info will only output for the master processor (correct me if wrong)? If you want it to output the results for each processor you have to use Pout instead of Info. |
So how can i call it in the molecule.c ?
