-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Turbulence model implementation errors (http://www.cfd-online.com/Forums/openfoam-programming-development/81895-turbulence-model-implementation-errors.html)
elbertj November 10, 2010 02:48
2 Attachment(s)
Dear Foamers,
I have implemented a non-linear eddy viscosity model, by modifying the kOmegaSST and including additional non-linear terms (code attached). I get a number of errors as:
no matching function to call to 'Foam:: .....'
final error as:
BSLEARSM.C:254: instantiated from here
/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/FieldFunctions.C:695: error: no match for ‘operator&&’ in ‘*(f2P ++) && *(f3P ++)’
/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/FieldFunctions.C:695: note: candidates are: operator&&(bool, bool) <built-in>
/home/ejp/codes/OpenFOAM/OpenFOAM-1.7.x/src/OpenFOAM/lnInclude/dimensionSet.H:285: note: Foam::dimensionSet Foam::operator&&(const Foam::dimensionSet&, const Foam::dimensionSet&)
make: *** [Make/linuxGccDPOpt/BSLEARSM.o] Error 1
Seems like I'm getting an error due to wrong use of double inner product operator (&&) and consequently with dimensions. However, I am unable to spot the error with the formula implementation. Kindly let me know if you know the source of error
Thanks,
Elbert
niklas November 10, 2010 07:26
Is IV_ a scalar or tensor?
IV_( (S_&&W_)&&W_),
If it is a scalar there should be a normal matrix multiplication somewhere
either
IV_( (S_&W_)&&W_)
or
IV_( S_&& (W_ & W_) )
niklas November 10, 2010 08:28
some other issues...
C1prime_ is defined as a volScalarField, but its just a constant, so I would change it to dimensionedScalar, otherwise you need to supply size information et.c....
Beta2_ is a volScalarField, but you cant just initialize it with a value it needs more information than
that. (same error as C1prime_)
To get it to compile i just set it to
Beta2_( 0.*N_), // why use a volScalarField for a zero?
but Im guessing that it really should be something else, otherwise why have it :)
aij_ is a symmetric tensor
W_ is a tensor and
W_ & W_ is just a tensor multiplication, this does not imply that the result is a symmetric tensor.
sure in this example it will be, but the code sees this as any other tensor multiplication
so you need to explicitly extract the symmetric part.
aij_
Beta1_ *S_
+ Beta2_ * ( (S_ & S_)-(1./3.)*(IIs_ * I ))
+ Beta3_ * (symm(W_ & W_)-(1./3.)*( IIo_*I)) // why should a tensor multiplication yield a symm tensor?
+ Beta4_*symm((S_ & W_)-(W_ & S_))
+ Beta6_*(symm(((S_ & W_) & W_) + ((W_ & W_) & S_)) - (2./3.)*IV_*I - IIo_*S_)
+ Beta9_*(symm(((W_ & S_) & (W_ & W_)) - ((W_ & W_) & (S_ & W_)) + 0.5*IIo_*((S_ & W_) - (W_ & S_))))
elbertj November 11, 2010 17:03
1 Attachment(s)
Hi Niklas,
Thanks, after making changes you suggested, it is working! I did this for aij_ ,
aij_ = symm(
Beta1_*S_
+ Beta2_*((S_ & S_)-(1./3.)*IIs_*I)
+ Beta3_*((W_ & W_)-(1./3.)*IIo_*I)
+ Beta4_*((S_ & W_)-(W_ & S_))
+ Beta6_*(((S_ & W_) & W_) + ((W_ & W_) & S_) - (2./3.)*IV_*I - IIo_*S_)
+ Beta9_*(((W_ & S_) & (W_ & W_)) - ((W_ & W_) & (S_ & W_)) + 0.5*IIo_*((S_ & W_) - (W_ & S_)))
Are you saying that though A_ = W_ & W_ is symmetric it has to be explicitly said, as
A_=symm(W_&W_) ?
In the constructor portion of my BSLEARSM.C (attached) , can you please tell me how I can include this code:
forAll(N_,cellI)
if(P2_[cellI] >= 0)
N_[cellI]= (C1prime_.value()/3.)+pow((P1_[cellI]+sqrt(P2_[cellI])),(1./3.))
+sign(P1_[cellI]-sqrt(P2_[cellI]))*pow(mag(P1_[cellI]-sqrt(P2_[cellI])),(1./3.));
else
N_[cellI]= (C1prime_.value()/3.)+2.*pow((sqr(P1_[cellI])-P2_[cellI]),(1./6.))
*cos((1./3.)*acos(P1_[cellI]/(sqrt(sqr(P1_[cellI])-P2_[cellI]))));
-Elbert
niklas November 12, 2010 03:02
A_=symm(W_&W_) ?
Yes, because
in the tensor class the multiplication operation between two tensors returns another tensor,
not a symmetric tensor.
N_(scalar(0.)*IIs_),
This is a good start if the dimensions of IIs_ and N_ are the same otherwise use another field
which has the same dimensions as N_ or a constructor like the one for nut_.
For that kind of complicated expressions you have to place it in here.
    bound(omega_, omega0_);
    nut_ = a1_*k_/max(a1_*omega_, F2()*mag(symm(fvc::grad(U_))));
//    nut_ = k_/(omega_+smallOmega_);
    nut_.correctBoundaryConditions();
    // calculation of N_ goes here ....
    printCoeffs();
maolongliu December 21, 2010 05:51
Hi, I am also using this model.
Which reference did you use to write this model.
Because your correlations are a little different with mine.
Originally Posted by elbertj (Post 282837)
Dear Foamers,
final error as:
Thanks,
Elbert
elbertj December 21, 2010 09:25
I used the formulation described here:
"Explicit Algebraic Reynolds Stress Models for Anisotropic Wall-Bounded Flows", F.R. Menter, A.V. Garbaruk, and Y. Egorov.
EUCASS – 3rd European Conference for Aero-Space Sciences, July 6-9th 2009 Versailles
maolongliu December 22, 2010 04:34
Does this model work well?
I use the formula of " Wallin, S. and A. Johansson (2000). "An explicit algebraic Reynolds stress model for incompressible and compressible turbulent flows." Journal of Fluid Mechanics 403: 89-132 ", it does not work quite well.
I want to try this one you use. Would you mind to send me the reference you use because I cannot find the file.
my mail: maolongliu@gmail.com
Thank you.
cfdmarkus December 26, 2010 14:47
Hi Elbert,
I am also using the WJ model. The reference you are using seem much newer.
Would it be possible for you to send me copy as well please: mw405@soton.ac.uk
Thanks, Markus.
florian_krause June 17, 2011 11:07
    printCoeffs();
Hi Niklas,
I recently had a similar issue when implementing Wilcox 1998 k-omega model (http://turbmodels.larc.nasa.gov/wilcox.html), which is different than the k-omega model implemented in OF (Wilcox 1988 k-omega model).
I have the following expression
    forAll(fBetaStar_, cellI)
    if(xiK_[cellI] <= scalar(0))
        fBetaStar_[cellI] = scalar(1);
    else
        fBetaStar_[cellI] = (scalar(1)+680*sqr(xiK_[cellI]))/(scalar(1)+400*sqr(xiK_[cellI]));
and I was wondering where to place it in the constructor. Well, I placed it where you suggested above and it works.
Why should it be placed there and how is that related to the complexity of the expression?
Thanks and best regards,
Florian
