November 10, 2010, 04:04 |
fixedMeanValue "namespace" error
Hi to all,
I tried to add fixed MeanValue boundary condition to my cavitatingFoam but when i execute it using wmake it is showing the following error fixedMeanValueFvPatchField.H:41: error: ‘namespace’ definition is not allowed here Can anybody help me in this regard Thanks |
December 11, 2010, 07:38 |
If I'm not mistaken, you should apply the boundary conditions on the 0 folder of your case. It makes no sense to compile boundary conditions since they are set at "user level". Which is the case you are running? Is it a tutorial? Depending on the parameter you are trying to set (U, p,...) there are different options of patchField types (fixedValue, fixedGradient, fixedNormalSlip...). Regards |
December 13, 2010, 03:00 |
#3 | |
I am using tutorial. But, now i solved the problem. I had some problem with permissions. Now everything is ok. Any how thanks for your reply, Cheers. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[Netgen] Compiling Netgen on Fedora Core is driving me crazy | jango | OpenFOAM Meshing & Mesh Conversion | 3 | November 9, 2007 13:29 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
