loop over mesh points in parallel run
Old   October 29, 2017, 10:10
Default loop over mesh points in parallel run
Nima Samkhaniani
nimasam is on a distinguished road
i would like to change the mesh points based on a function during run, the algorithm works fine in serial, but for parallel run, mesh.points() only returns the position of points in one processor. do you have any ideas, how to access to each processors mesh data?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 30, 2017, 04:33
Jibran
Jibran is on a distinguished road
You can use the globalMeshData class to get this information. Specifically, I would recommend to have a look at the volPointInterpolation class where the member functions syncUntransformedData() and pushUntransformedData() use this information.
Jibran Haider
https://jibranhaider.com/
Jibran is offline   Reply With Quote
mesh data, mesh points, parallel, processor
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
Run in parallel slow and cannot open the mesh in Paraview qjh888 OpenFOAM Running, Solving & CFD 0 July 13, 2016 04:55
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
