multiRegion version of pisoFoam
Hello developers,
Perhaps somewhat of a double post, as I posted a similar message in the Running/Solving section of this forum, but to no avail.... Well, my problem is that I'm trying to run a double region simulation by implementing a modified version of pisoFoam. I think I've come quite far in my implementation, and when starting a run my solver reads the correct meshes, with the correct number of cells, the right names, correct implementation of the turbulence model, etc. So far so good. However, when starting the time loop, OpenFOAM complains about not finding region0 (which is the standard region, but which I don't have since I named my regions differently.) I get the following error: Code:
--> FOAM FATAL ERROR: Would someone have an idea on how to fix this? Kind regards, Francois. |
Hum..
I've pinpointed the error origin to the command: Code:
runTime++; Looking forward to your replies! Francois. |
And in Time.C, the problem occurs in the function:
Foam::Time& Foam::Time::operator++() Code:
00645 if (!subCycling_) Kind regards, Francois. |
You can just use my chtIcoMultiRegion solver with zero solid regions.
http://www.cfd-online.com/Forums/ope...egionfoam.html |
Dear Fabio,
Thank you for your reply and for the solver. But oh my! Is it Christmas coming early? :) I'll look through it and come back to you if I have any questions. Kind regards, Francois. |
Dear Fabio,
I used the incompressible multiRegion solver you developed to try and run the case I was describing, but I encounter the same error... The only modifications I made to the solver was to kick out the reading of the "K", "T", "Pr" etc variables since I was not planning on using them, and my programme compiled without errors. I then used the same two region meshes I had defined earlier, and set solidRegionNames in the ./constant/regionProperties file to Code:
solidRegionNames ( ) Any ideas? :confused: :( :confused: Kind regards, Francois. |
Add a dummy region.. that do nothing.. zeroGradient in all boundaries.
I had a problem with chtIcoMultiRegionFoam compilation with 1.7.x In the file: chtIcoMultiRegionFoam/derivedFvPatchFields/solidWallMixedTemperatureCoupled/solidWallMixedTemperatureCoupledFvPatchScalarField .C just add #include "mapDistribute.H" like this: #include "solidWallMixedTemperatureCoupledFvPatchScalarFiel d.H" #include "addToRunTimeSelectionTable.H" #include "fvPatchFieldMapper.H" #include "volFields.H" #include "directMappedPatchBase.H" #include "mapDistribute.H" #include "regionProperties.H" maybe could help someone. Jean |
