extract information from sample during simulation for use
Old   January 10, 2011, 13:51
Default extract information from sample during simulation for use
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Hi all,
I am using interFoam and wanna to extract the position of the interface every timestep for later use (for calculating height function). I found that I can use sample to extract the interface at alpha1 = 0.5. In /OpenFOAM-1.6/src/sampling/sampledSurface/sampledSurfaces/sampledSurfaces.C there is a function to write the positions and index of points (s.points() and s.faces()) on the surface called writeGeometry():
158 void Foam::sampledSurfaces::writeGeometry() const
159 {
186 genericFormatter_->write
187 (
188 outputDir,
189 s.name(),
190 s.points(),
191 s.faces()
192 );
193 }
What I did is create a function in sampleSurfaces.H like:
224 const vectorField iso_points()
225 {
226 return iso_points_;
227 };
and try to assign the value of s.points() to the value iso_points() later like:
iso_points_ = s.points();
But then when I compiled, I got the error: sampledSurface/sampledSurfaces/sampledSurfaces.C:198: error: passing 'const Foam::vectorField' as 'this' argument of 'void Foam::Field<Type>:perator=(const Foam::Field<Type>&) [with Type = Foam::Vector<double>]' discards qualifiers
I try different ways to get that information but it did not work. If you have any ideas or ways to extract that information for using in the solver, i would very appreciate to hear.
Regards,
Duong
duongquaphim is offline   Reply With Quote
Fuse simulation canopy Main CFD Forum 0 February 11, 2009 03:24
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 19:19
Transient simulation Error information Li CFX 0 July 25, 2007 11:27
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
