Some cells have disappeared
Hi all,
I have added two lines to pisoFoam to count the number of cells: const cellList& cells = mesh.cells(); Info << " no cells: " << cells.size() << endl; When I run it on a single processor it counts: 1278060 cells - which is correct. But when I decompose the case and run it on 16 processsors, the number reduces to: 79043 cells. This is approx. 1/16 of the total number of cells. Consequently, when I loop over all cells using "forAll(cells,cellI)" some cells are always missing :( Does anyone know why mesh.cells() does not include all cells when run in parallel and how can the missing cells be accessed? Thanks Markus |
Hi Markus,
you must gather the information to the master: Code:
const cellList& cells = mesh.cells(); |
Thank you Martin!
field manipulation with parallel computations
Thanks for the thread on this subject first.
I've managed to get number of cells in parallel computing as Martin suggested but I still have a problem with modifying 'field' itself. here is the code I use const cellList& cells = mesh.cells(); label nCells = 0; nCells= cells.size(); reduce(nCells, sumOp<label>()); scalar i = 0; forAll(cells, celli){ i++; } Info<<"i= "<<i <<nl; Info<<"nCells= " <<nCells<<nl; with a single processor, it shows: i= 336000 nCells= 336000 with 4 processors, it shows: i= 84332 nCells= 336000 as you can see, nCells isn't affected by multi processing but the field loop number (i) is depending on the number of processors. So question is that is there any way that I can manipulate field (say velocity) with the parallel compuations ? What I want to do is imposing artificial fluctuations on one plane in the middle of domain. I also wrote same question in this forum but no response so far, http://www.cfd-online.com/Forums/ope...mputation.html Thanks in advance Yusik |
Hi Yusik,
you can manipulate the field within the loop: forAll(cells, celli) { i++; // your manipulation here, each processor will manipulate // its part of the field. } Hmmhhh, not sure if I understand your problem correctly, maybe you can provide some code snippets of your intended algorithm... Martin |
Yes, it works. you are right Martin. I was a different problem. I replied to other thread (link below). Thanks for your help. :D
http://www.cfd-online.com/Forums/ope...tml#post320892 |
