-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   evaluate surface of the patchField (http://www.cfd-online.com/Forums/openfoam-programming-development/82976-evaluate-surface-patchfield.html)
Cyp December 10, 2010 06:06
hello!
I am facing a new problem : I do not know how to evaluate the surface of a patchField labeled patchID.
I was thinking about
p.boundaryField[patchID].magSf();
but it doesn't work.
Thank you very much for your help,
Cyp
MartinB December 10, 2010 06:25
Hi Cyp,
try:
p.boundaryField()[patchID].magSf();
Martin
Cyp December 10, 2010 06:29
Hi Martin!
It doesn't work neither...
(in fact it was what I tried... my first post was a typo)
MartinB December 10, 2010 06:49
May be
mesh.magSf().boundaryField()[patchID];
Can you post some more code?
Martin
Cyp December 10, 2010 08:14
It still doesn't work...
This is the piece of code I consider:
    surfaceScalarField phiKsa = fvc::interpolate(kSa);
    surfaceScalarField phiKsb = fvc::interpolate(kSb);
    surfaceScalarField phiP
        IOobject
            "phiP",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionedScalar("zero", dimensionSet(1, -2, -2, 0, 0), 0.0)
    phiP = ((-fvc::interpolate(Ub+Ua)&mesh.Sf())+((rhoa*phiKsa+rhob*phiKsb)*g&mesh.Sf()))
            / (phiKsa + phiKsb)/mesh.magSf().boundaryField()[patchID];
MartinB December 10, 2010 08:36
phiP.boundaryField() = ((-fvc::interpolate(Ub+Ua)&mesh.Sf())+((rhoa*phiKsa+rhob*phiKsb)*g&mesh.Sf()))/(phiKsa + phiKsb)/mesh.magSf().boundaryField();
What's the error message? Is it one of the standard solvers of OpenFOAM, so I can check it?
May be you can loop over the patches like here:
volVectorField tau
            IOobject
                "tau",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            mesh,
            dimensionedVector
                "tau",
                Reff.dimensions(),
                vector::zero
        forAll(tau.boundaryField(), patchi)
            tau.boundaryField()[patchi] =
                -mesh.Sf().boundaryField()[patchi]
                /mesh.magSf().boundaryField()[patchi]
            ) & Reff.boundaryField()[patchi];
Cyp December 10, 2010 10:46
thank you very much for your help. It works now!
    scalarField fluxP = -(phi.boundaryField()[patchID])
                /(kSa.boundaryField()[patchID]+kSb.boundaryField()[patchID])
