-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   error in eclipse (http://www.cfd-online.com/Forums/openfoam-programming-development/83274-error-eclipse.html)
Linda December 22, 2010 05:08
error in eclipse
I tried to test a solver according to
http://openfoamwiki.net/index.php/Ho...M_with_Eclipse
After I imported the pitzDaily project in eclipse and run the programme, there is always an error
"/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linuxGccDPDebug/simpleFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory".
Could you please help about it?
Thanks
Linda
mvoss December 22, 2010 05:16
hey,
did you set up the make/files properly?
neewbie
Linda December 22, 2010 05:20
How to setup the make/file?
sorry i am a newbie.
mvoss December 22, 2010 05:24
so am i...
sorry, i meant the make/options.
there has to be smth. like
EXE_INC = \
EXE_LIBS = \
    -lcompressibleTurbulenceModel \
Linda December 22, 2010 21:23
Do you mean building the openfoam sources? I use the script
'./Allwmake'. It should build everything.
And I execute the foamInstallationTest script and got
'Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/ylz/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/ylz/OpenFOAM/ylz-1.7.1 yes no
$WM_THIRD_PARTY_DIR /home/ylz/OpenFOAM/ThirdParty-1.7.1 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/ylz/OpenFOAM/OpenFOAM-1.7.1 yes yes yes
$FOAM_APPBIN ...7.1/applications/bin/linuxGccDPDebug yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.7.1/bin/linuxGccDPDebug no no
$FOAM_USER_APPBIN ...7.1/applications/bin/linuxGccDPDebug no no
$WM_DIR /home/ylz/OpenFOAM/OpenFOAM-1.7.1/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.7.1/lib/linuxGccDPDebug yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.7.1/lib/linuxGccDPDebug no no
$FOAM_USER_LIBBIN ...enFOAM/ylz-1.7.1/lib/linuxGccDPDebug no no
$MPI_ARCH_PATH ...7.1/platforms/linuxGcc/openmpi-1.4.1 yes yes yes
Third party software
Software Version Location
gcc 4.4.5 /usr/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.23 /bin/tar
icoFoam 1.7.1 ...penFOAM-1.7.1/applications/bin/linuxGccDPDebug/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
So do you think it is the problem from the openfoam or setup of eclipse?
regards
yali
Linda December 22, 2010 22:23
when I use 'wmake' to compile, i run into such problem:
ylz@ubuntu:~/OpenFOAM/OpenFOAM-1.7.1$ wmake Make/linux64Gcc4DPOpt/<object>.o
bash: object: No such file or directory
ylz@ubuntu:~/OpenFOAM/OpenFOAM-1.7.1$ wmake libso
wmake error: 'Make' directory does not exist
Are they related to the problem resulted from the eclipse?
Linda December 23, 2010 02:13
I checked the make/options in the simplefoam;
"EXE_INC = \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/RASModel \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/transportModels/incompressible/singlePhaseTransportModel \
-I$(LIB_SRC)/finiteVolume/lnInclude
EXE_LIBS = \
-lincompressibleTurbulenceModel \
-lincompressibleRASModels \
-lincompressibleTransportModels \
-lfiniteVolume
Is it correct? Please advise. 3x
mvoss January 3, 2011 04:00
hi,
seems okay to me.
Are you trying to create a library ? Did you choose the right kind of project ("..with Makefile") while setting up the case in eclipse?
neewbie
