Solve single but higher order equation by OF 1.6 suffering Problem
Old   December 23, 2010, 13:53
Unhappy Solve single but higher order equation by OF 1.6 suffering Problem
yijin Mao
alundilong is on a distinguished road
Hi forks,
I am trying to solve a equation like this,
fvm::d2dt2(Qaplha,T)
+ fvm::ddt(Ralpha,T)
- fvm::ddt(tauT,T) // this is new term represents ddt(tau,laplacian(T))
- fvm::laplacian(con, T)
The red line is a 3 order differential term which OF cannot solve, in my opinion, a mix application from fvm::ddt and fvc::laplacian may be helpful, however, a fatal error was also produced, see lines in red below!
codes has been implemented into
Errors Message:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
I believe there is something wrong with tmp<ddtScheme<Type>> which is responsible for managing temporary objects, but I can not figure it out.
Hoping to hear your suggestions.
alundilong is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Visualization of higher order solution shyamdsundar Main CFD Forum 1 July 23, 2010 03:55
solving the extra equation for 2D problem sujath FLUENT 0 June 20, 2005 17:53
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
