Home > Forums > OpenFOAM Programming & Development
thickened flame model
Like Tree4Likes
  • 3 Post By remir
  • 1 Post By remir
Old   January 20, 2011, 14:05
Default thickened flame model
usergk is on a distinguished road
Hi
I came across some previous code on the thickened flame model that uses the following for the source term:
Does anyone know what the scalars A, TA, MF etc signify?
Thanks,
gk
namespace Foam
defineTypeNameAndDebug(airmix, 0);
addToRunTimeSelectionTable(sourceTerm, airmix, dictionary);
airmix::airmix(/*const volScalarField& b*/ const hCombustionThermo& thermo)
: sourceTerm(typeName, thermo),
A_(readScalar(coeffsDict_.lookup("A"))),
TA_(readScalar(coeffsDict_.lookup("TA"))),
MF_(readScalar(coeffsDict_.lookup("MF"))),
nuF_(readScalar(coeffsDict_.lookup("nuF"))),
nuO_(readScalar(coeffsDict_.lookup("nuO"))),
phi_(0.0),
stOF_(0.0)
dimensionedScalar stof(thermo.lookup("stoichiometricAirFuelMassRatio"));
stOF_=stof.value();
if (!thermo_.composition().contains("ft"))
phi_=readScalar(coeffsDict_.lookup("phi"));
airmix::~airmix()
void airmix::correct(const volScalarField& T)
const scalar MO2=32;
const volScalarField& b_ = thermo_.composition().Y("b");
const volScalarField& rho = //thermo_.rho(); //thermo.rho has uncorrected BC's! Do not use
T.db().lookupObject<volScalarField>("rho"); //lookup returns rho field from top level solver
if (thermo_.composition().contains("ft"))
const volScalarField& ft=thermo_.composition().Y("ft");
forAll(omega_, I)
scalar maxYF= ft[I];
scalar YF= b_[I]*ft[I]
+(1.0 - b_[I])*max(thermo_.composition().fres(ft[I], stOF_), 0.0);
scalar YO2= 0.233005 * (1.0 - ft[I] - (ft[I] - YF)*stOF_);
omega_[I]=maxYF>SMALL ? 1e3* // from cgs
A_ * nuF_ * MF_
*pow( 1e-3*rho[I]*YF / MF_, nuF_ ) // rho is kg/m^3, change to cgs
*pow( 1e-3*rho[I]*YO2 / MO2, nuO_ )
*exp(-TA_/T[I])
/maxYF : 0.0;
forAll(omega_.boundaryField(), bI)
forAll(omega_.boundaryField()[bI], fI)
scalar maxYF= ft.boundaryField()[bI][fI];
scalar YF= b_.boundaryField()[bI][fI]*ft.boundaryField()[bI][fI]
+(1.0 - b_.boundaryField()[bI][fI])*
max(thermo_.composition().fres(ft.boundaryField()[bI][fI], stOF_), 0.0);
scalar YO2= 0.233005 * (1.0 - ft.boundaryField()[bI][fI]
- (ft.boundaryField()[bI][fI] - YF)*stOF_);
omega_.boundaryField()[bI][fI]=maxYF > SMALL ? 1e3*
A_ * nuF_ * MF_
*pow( 1e-3*rho.boundaryField()[bI][fI]*YF / MF_, nuF_ )
*pow( 1e-3*rho.boundaryField()[bI][fI]*YO2 / MO2, nuO_ )
*exp(-TA_/T.boundaryField()[bI][fI])
/maxYF : 0.0;
else
scalar maxYF=1.0/((stOF_/phi_)+1.0);
scalar YLex=1.0 - maxYF - stOF_*maxYF;
forAll(omega_, I)
scalar YF = maxYF * b_[I];
scalar YO2 = 0.233005 * (1.0 - maxYF) * b_[I]
+ 0.233005 * YLex * (1.0 - b_[I]);
omega_[I]=1e3* // from cgs
A_ * nuF_ * MF_
*exp(-TA_/T[I])
/maxYF;
scalar YF = maxYF * b_.boundaryField()[bI][fI];
scalar YO2 = 0.233005 * (1.0 - maxYF) * b_.boundaryField()[bI][fI]
+ 0.233005 * YLex * (1.0 - b_.boundaryField()[bI][fI]);
omega_.boundaryField()[bI][fI]=1e3*
A_ * nuF_ * MF_
/maxYF;
usergk is offline   Reply With Quote
Old   January 20, 2011, 15:32
It seems they refer to this:
Wb=−A*[Fuel]^nuF*[O2]^nuO*exp(−TA/T)
If so, does anyone know the exact values for propane?
Thanks,
gk
Old   June 14, 2014, 10:26
remi
remir is on a distinguished road
I know it's been a while, but did you find the answers to your questions?
I came across the same code for thickened flame model, and was trying to adapt it to OF2.2 or OF2.3. Any idea on where to start? (XiFoam I thought).
Thanks,
Remi
remir is offline   Reply With Quote
Old   January 20, 2015, 02:18
remi
Thought I'd give some feedback on this old post, as I've been working on the TF model recently:
Originally Posted by usergk View Post
Thanks,
gk
The constants refer to:
W= A*NuF*MF*[(rho*YF/WF)^NuF]*[(rho*YO/WO)^NuO]*exp(-Ta/T)
Values for propane are:
A=1.65.10^11 cgs
Ta=15080K
NuF=0.5
NuO=1
WF=44
WO=32
Source: Dynamically thickened flame LES model for premixed and non-premixed turbulent combustion. By J.P. Legier, T.Poisont and D.Veynante.
I have updated the thickened flame model to OF222, and compiled successfully the new solver. However, I encounter a problem when setting NuF to 0.5 : immediate simulation crash: Floating point exception (core dumped)
Changing the coefficient to 1 solves the problem, and there seems to be a limit around 0.7. I assume it has to do with the calculation of Omega in airmix.C, but can't find how.
Was there any major change from OF16 to OF222 that should be taken care of when adapting an old solver (in mesh, chemistry, units, etc..?).
I can send the solver to those interested in this problem.
Best,
R.
Heat80, Uyan and shuige like this.
Old   February 2, 2015, 12:55
Younis Najim
Heat80 is on a distinguished road
Hi Remi,
Would you please send me the code on this email (younisengmsu@gmail.com). I'm currently working methane/air combustion in closed channel using TFM in Fluent.
Thanks
Heat80 is offline   Reply With Quote
Old   February 2, 2015, 22:31
remi
Sure thing Younis.
Little upgrade on the code situation:
I located the problem causing the simulation crash, and changed a little the airmix.C file in order to fix it, even though the file itself was well coded originally. I think that at some point, the b field's minimum value might become a negative number ( -1.0e-08 or something), thus leading to negative values for species mass fraction, and a NaN value as soon as the term [Fuel]^nuF*[O2]^nuO is calculated, if NuF or NuO are not integers.
Thus, to avoid the problem (a real study should be conducted to see where it comes from though..), I added some max functions in the airmix file that has been linked by the original poster, as follow:
A_ * nuF_ * MF_
*pow( max(1e-3*rho[I]*YF / MF_,0), nuF_ ) // rho is kg/m^3, change to cgs
*pow( max(1e-3*rho[I]*YO2 / MO2,0), nuO_ )
*exp(-TA_/T[I])
/maxYF : 0.0;
Instead of e-mailing I tried uploading it here, tell me if you got everything.
Best,
Remi
Uyan likes this.
Old   February 5, 2015, 22:08
Younis Najim
Thank you Remi.
Old   May 5, 2015, 04:39
Default TF model
Kai Zheng
Zach Zheng is on a distinguished road
Originally Posted by Heat80 View Post
Hi Remi,
Thanks
Hi Najim,
I'm also working the premixed methane/air flame propagating in duct using the TF model and flame surface density (FSD) model in Fluent, but it seems that the premixed flame propagating very slow using the TF model, did you meet the same problem?
Zach Zheng is offline   Reply With Quote
Old   June 30, 2015, 15:53
Younis Najim
Hi Zheng,
Sorry for my late reply. This is due to the turbulent flame speed model which is a function of flow parameters, geometry, initial conditions, and so on. What I know from ANSYS tutorial is the turbulent flame speed has to be set accurately when you work with TFM. Try to use Metghalchi-Keck for laminar flame speeds (material>properties>laminar flame speed> Metghalchi-Keck>type of fuel you are using. Is the your combustion chamber closed or open/parially open?
thanks
Y. Najim
Old   July 27, 2015, 09:47
Stefano Puggelli is on a distinguished road
Hi Foamers,
Can someone explain me why in the airmix.C file a 1e+3 conversion is exploited for the pre-exponential constant A? In my opinion this constant should be proportional to the order of the reaction..
Stefano
Stefano Puggelli is offline   Reply With Quote
Old   June 9, 2016, 07:15
Default ATF : thermophysicalProperties
  #11
Uyan is on a distinguished road
Hi All,
I am trying to use ATF model to simulate premixed methane flame.
I need to know how to modify the thermophysicalProperties dictionary. I am having some troubles understanding the entry nMoles.
reactants
    specie
        nMoles          42.7719;
        molWeight       29.48;
    thermodynamics
        Tlow            200;
        Thigh           5000;
        Tcommon         1000;
        highCpCoeffs    (3.26219 1.90578e-03 -6.70778e-07 1.11111e-10 -6.95161e-15 -1.54131e+03 4.51236);
        lowCpCoeffs     (3.19463 2.23757e-03 -2.87044e-06 3.71954e-09 -1.67996e-12 -1.47394e+03 4.96249);
    transport
        As              1.67212e-06;
        Ts              170.672;
I don't understand how the nMoles entry became 42.77 for propane in this tutorial case. To make things worse the nMoles for products is 43.77.
Because I think nMoles has to be 1, considering one mole of reactants is used.
Can someone please help me here what is going on with nMoles entry?
Uyan is offline   Reply With Quote
Old   June 21, 2016, 08:20
Default myATF ---- ftEqn and ft field
  #12
Hi remir all,
Does anyone know what exactly is the purpose of ftEqn.H file is.
And in the test case that was kindly provided by remir there is a file "ft"
What exactly is the purpose of that file?
Can someone who has used this solver please help me here.
Thanks a lot.
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 10:52
lighter flame model douglasbloer Main CFD Forum 0 July 1, 2010 11:35
Crosswind flame with reactingFoam torvic OpenFOAM Running, Solving & CFD 1 September 10, 2007 17:48
