-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Turbulent dispersion of particle tracking in LES (http://www.cfd-online.com/Forums/openfoam-programming-development/84175-turbulent-dispersion-particle-tracking-les.html)
mittal January 22, 2011 04:02
OpenFOAM source code has RANS based turbulent dispersion models for particle tracking but not LES. To build a LES based dispersion model, I tried to modify file DispersionRASModel.C and DispersionRASModel.H in the directory /OpenFOAM/OpenFOAM-1.6/src/lagrangian/intermediate/submodels/Kinematic/DispersionModel/DispersionRASModel
My idea was to force above mentioned files access LES data (instead of RANS data) without changing the model name (the dispersion model name still remains StochasticDispersionRAS or GradientDispersionRAS but it would become LES based, if successful). ofcourse, calculations will change, but i plan to take care of them later on. just trying to check if it works first.
so following are the changes that I make (in red)
#include "DispersionRASModel.H"
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
template<class CloudType>
Foam:: DispersionRASModel<CloudType>:: DispersionRASModel
const dictionary& dict,
CloudType& owner
DispersionModel<CloudType>(dict, owner),
turbulence_
owner.mesh().objectRegistry::lookupObject<compress ible::LESModel>
"LESProperties"
kPtr_(NULL),
ownK_(false),
epsilonPtr_(NULL),
ownEpsilon_(false)
// * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * //
Foam:: DispersionRASModel<CloudType>::~DispersionRASModel ()
cacheFields(false);
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
void Foam:: DispersionRASModel<CloudType>::cacheFields(const bool store)
if (store)
tmp<volScalarField> tk = this->turbulence().k();
if (tk.isTmp())
kPtr_ = tk.ptr();
ownK_ = true;
else
kPtr_ = tk.operator->();
ownK_ = false;
tmp<volScalarField> tepsilon = this->turbulence().epsilon();
if (tepsilon.isTmp())
epsilonPtr_ = tepsilon.ptr();
ownEpsilon_ = true;
else
epsilonPtr_ = tepsilon.operator->();
ownEpsilon_ = false;
else
if (ownK_ && kPtr_)
delete kPtr_;
ownK_ = false;
if (ownEpsilon_ && epsilonPtr_)
delete epsilonPtr_;
file DispersionRASModel.H
#ifndef DispersionRASModel_H
#define DispersionRASModel_H
#include "DispersionModel.H"
#include "LESModel.H"
namespace Foam
Class DispersionRASModel Declaration
class DispersionRASModel
public DispersionModel<CloudType>
protected:
// Protected data
//- Reference to the compressible turbulence model
const compressible::LESModel& turbulence_;
// Locally cached turbulence fields
//- Turbulence k
const volScalarField* kPtr_;
//- Take ownership of the k field
bool ownK_;
//- Turbulence epsilon
const volScalarField* epsilonPtr_;
//- Take ownership of the epsilon field
bool ownEpsilon_;
public:
//- Runtime type information
TypeName("DispersionRASModel");
// Constructors
//- Construct from components
DispersionRASModel
CloudType& owner
//- Destructor
virtual ~DispersionRASModel();
// Member Functions
//- Cache carrier fields
virtual void cacheFields(const bool store);
//- Return const access to the turbulence model
const compressible::LESModel& turbulence() const
return turbulence_;
} // End namespace Foam
#ifdef NoRepository
# include "DispersionRASModel.C"
#endif
#endif
so when i run my simulation, it throws error
:lookup of LESProperties from objectRegistry region0 successful
but it is not a LESModel, it is a Smagorinsky#0 Foam::error:: printStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
In original code, it searched for file:RASProperties (which I change to LESProperties file here) and looked for the RASModel (here i make it search for the LESModel). So why it does not accept Smangroski as LESModel while the original code successfully accepted kEpsilon option for RASModel.
Could you please guide me so that I can prepare a template for LES based turbulent dispersion model.
Many many thanks for your help and considersation,
Regards,
Kushagra
N. A. February 8, 2011 19:26
Hello there,
So I was trying to implement a LES based dispersion model (Apte and Moin). its based on solving Langevin equation. I have not started yet, but I was experimenting to add a particule dispersion model.
So I went on and renamed GradientDispersionRAS to myGradientDispersionRAS. I also changed whereever the word was GradientDispersionRAS to myGradientDispersionRAS.
Few of the files I had to do was:
makeReactingParcelDispersionModels.H (intermediate/parcels/include/makeReactingParcelDispersionModels.H)
makeParcelDispersionModels.H (intermediate/parcels/include/makeReactingParcelDispersionModels.H)
myGradientDispersionRAS.H (intermediate/submodels/Kinematic/DispersionModel/myGradientDispersionRAS/myGradientDispersionRAS.H)
myGradientDispersionRAS.C (intermediate/submodels/Kinematic/DispersionModel/myGradientDispersionRAS/myGradientDispersionRAS.H)
___________
But when I run the coalChemistryFoam, it still says that the only option I have is one among the following 3 dispersion models:
--> FOAM FATAL ERROR:
Unknown DispersionModelType type myGradientDispersionRAS, constructor not in hash table
Valid DispersionModel types are:
3
none
From function DispersionModel<CloudType>::New(const dictionary&, CloudType&)
in file /home/NA/OpenFOAM/OpenFOAM1.7.x/src/lagrangian/intermediate/lnInclude/NewDispersionModel.C at line 54.
I am at a total loss why would it do, inspite of the fact that all the libraries were compiled successfully. yes I also compiled after deleting lninclude and Make/linux64GccDPOpt directories. I also compiled the coalChemsitryFoam solver also.
Any suggestions will be helpful.
Kushagra,
Can you try this and let me know if you are also getting the same issue.
Thanks,
Nir
mittal February 9, 2011 00:35
I am just a beginner in OpenFOAM. You get this error because your new model 'myGradient--------' has not been added to the object list. The code does not know if this key 'myGradient--------' word. Yes, your code may compile because all the files/libraries it needs are accessible to it. But successful compilation does not mean that you code will do what you want it do. It is just like convergence in CFD. convergence does not mean you will get RIGHT solution. yes, you will get a solution but it may be wrong or right. Does it make more clear?
Now how to add your new model option to objects list ( I may not be using right words from OpenFOAM programming perspective but blame should go to my lack of experience with it)? I did it at some point but do not remember it right now. Do one simple thing. Use cat and grep command to find which other files use StochasticRAS----- or Gradient----- words. One of them must be adding these models to the code. Just use existing code in that file to add your model to the code.
Good Luck,
Kushagra
N. A. February 9, 2011 01:08
Hi Kushagra,
I acutally did a grep search of word GradientDispersionRAS and thats how I proceeded. I found that there are 4 files that use GradientDispersionRAS:
GradientDispersionRAS.H (intermediate/submodels/Kinematic/DispersionModel/GradientDispersionRAS/GradientDispersionRAS.H)
GradientDispersionRAS.C (intermediate/submodels/Kinematic/DispersionModel/GradientDispersionRAS/GradientDispersionRAS.H)
Can you please try renaming it and see if you are able to run coalChemistryFoam with a modified name. With this I can confirm if I am missing any other files. I found that there are only four above files that are involved with turbulent dispersion.
Thanks,
Nir
chegdan February 23, 2011 19:01
wmake libso?
This type of error is often encountered when making a new boundary condition, custom linear system solver, etc. I would suggest making a dynamic library from your dispersion model into something named libMyDispersionModel and then including the line.
libs("libMyDispersionModel.so")
in your controlDict file of the solver you want to use your dispersion model in. This is similar to the explanation for adding a new boundary condition in:
http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf
Thats probably not clear (my brain is fighting to write clearly right now), but its a quick answer.
hope that helps.
Dan
