Navier-Stokes Equation and icoFoam
Like Tree3Likes
  • 1 Post By kathrin_kissling
  • 2 Post By santiagomarquezd
Old   February 1, 2011, 04:00
Default Navier-Stokes Equation and icoFoam
Nick Mai
nickmai123 is on a distinguished road
I was wondering if anyone could help me answer a question related to the implementation of the icoFoam solver. According to the code presented here, the momentum equation as stated in the icoFoam solver is:
fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) == -fvc::grad(p).
I do not get where the term "fvm::div(phi,U)" is coming from, as the classic incompressible laminar equations typically have this term as "U.div(U)". How is the flux, phi, defined for this solver?
Also, I looked at Dr. Jasak's explanation beginning in section 3.8 of his Ph.D. thesis, and there he writes "div(UU)". How is that related to the normal definition of "U.div(U)". Is one of the U's an implied scalar?
Many thanks to all who help! I am just an undergrad, so much of this is beyond my knowledge and current understanding.
nickmai123 is offline   Reply With Quote
Old   February 1, 2011, 05:02
Cyp
Cyprien
Cyp is on a distinguished road
Hi nickmai!
phi is the projection of the velocity field on the face of your cells. It is defined as :
surfaceScalarField phi = linearInterpolation(U) & mesh.Sf()
It has the dimension of m^3/s (velocity * surface). It is created in createField.H either with the previous snippet or by calling:
#include "createPhi.H"
Best regards,
Cyp
Cyp is offline   Reply With Quote
Old   February 2, 2011, 04:14
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hey,
in case you need a non-code reference you can find it in Hrvoje Jasak's thesis as well. The equation is on page 80 no (3.17)
Best
Kathrin
Woj3x likes this.
kathrin_kissling is offline   Reply With Quote
Old   February 2, 2011, 21:24
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Let's see, NS equations reads
dU/dt + U&grad(U) = -grad(p)+nu*laplacian(U)
Where & implies dot product.
Written in this form this equation is vectorial but has tensorial terms behind it, the term grad(U) is a gradient of a vector, a tensor. Then U&grad(U) is done, which is a vector again. To do things easier we can decompose this equation in three scalar components:
du/dt + U*grad(u) = -dp/dx+nu*laplacian(u)
dv/dt + U*grad(v) = -dp/dy+nu*laplacian(v)
dw/dt + U*grad(w) = -dp/dz+nu*laplacian(w)
where U=(u,v,w)
I
Also, I looked at Dr. Jasak's explanation beginning in section 3.8 of his Ph.D. thesis, and there he writes "div(UU)". How is that related to the normal definition of "U.div(U)". Is one of the U's an implied scalar?.
Second term of equations or convective acceleration is really
div(U tensorial U)
which can be transformed in
U & grad(U)
The form used in icoFoam resembles the first one, but in order to avoid the non-linearity arose from (U tensorial U) data from a previous time-step is used to assemble. Following equation in Hrv thesis p. 144, line 2, you have F=phi=U^0&S_f, and U_f=U_f^n. You are using U data from time-step 0 (past) and n (actual).
Regards.
Woj3x and fhjkfhjk like this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
interFoam vs icoFoam on a single-phase case nuovodna OpenFOAM Running, Solving & CFD 1 May 1, 2014 10:37
OpenFOAM wonbt solve the momentum U equation sek OpenFOAM Running, Solving & CFD 5 March 6, 2008 17:27
Equation discretisation in icoFoam kar OpenFOAM Running, Solving & CFD 3 February 10, 2008 07:34
Pressure Correction Equation morteza OpenFOAM Running, Solving & CFD 2 September 4, 2007 07:16
IcoFOAM and Navier Stokes juanduque OpenFOAM Running, Solving & CFD 0 May 8, 2007 11:43
