adding a turbulence model without recompiling the core
Old   February 17, 2011, 10:50
Default adding a turbulence model without recompiling the core
Sebastian Weiper
sebastianweiper is on a distinguished road
Hi Foamers,
I want to add a new turbulence model to Openfoam without recompiling the core.
The Compilation works fine but when i want to start the calculation this turbulence model is not known.
I compiled it to this location:
LIB = $(FOAM_USER_LIBBIN)/mylibincompressibleLESModels
I also make the right entry in the controldict.
Is it possible to add some turbulencemodels without recompiling the core of openfoam?
Software: OpenFOAM 1.5-dev
sebastianweiper is offline   Reply With Quote
Old   February 18, 2011, 03:17
Christian Lucas
Chris Lucas is on a distinguished road
this should work. Maybe you have to recompile the solver.
One question, why are you compiling the new model in a new dynamic library? Is the new model specially designed for one solver? If not, why not include the new model to the existing turbulence library (dynamic library).
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   February 19, 2011, 14:04
Retired Super Moderator
Bruno Santos
Greetings to both of you!
@sebastianweiper:
The location the library is perfect How can we be sure you made the right entry in controlDict, if you didn't post here the relevant entry?
Like Christian said, yes it should be possible. But there are a few details that need to be taken into account:
  • Your new model doesn't have the same name as some other model, does it?
  • In the modified code, did you rename all of the references to the old model?
  • Have you modified all of the necessary files in your case (files in constant and system) to use the new model?
  • Are you 100% certain that the name you defined in the code is perfectly identical to the name you use in the case files? One letter is enough for it to not respond! For example, "myIcLES" will not be recognized as "myICLES"!
@Chris Lucas:
One thing is working on our own computer, where we have access to every part of the file system and have superuser powers if we want (the almighty root user ); another thing is having to use a shared computer or cluster, where OpenFOAM is installed in "/opt" and making changes to it is not an option
Best regards,
Bruno
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
