adding a turbulence model without recompiling the core
Hi Foamers,
I want to add a new turbulence model to Openfoam without recompiling the core. The Compilation works fine but when i want to start the calculation this turbulence model is not known. I compiled it to this location: LIB = $(FOAM_USER_LIBBIN)/mylibincompressibleLESModels I also make the right entry in the controldict. Is it possible to add some turbulencemodels without recompiling the core of openfoam? |
this should work. Maybe you have to recompile the solver. One question, why are you compiling the new model in a new dynamic library? Is the new model specially designed for one solver? If not, why not include the new model to the existing turbulence library (dynamic library). Regards, Christian |
Greetings to both of you!
@sebastianweiper: Quote:
@Chris Lucas: Quote:
Best regards, Bruno |
