March 7, 2011, 12:43 |
PatchToPatchInterpolation parameters
Ivor Clifford
I was wondering if anyone knew exactly what the difference was between the different parameters to patchToPatchInterpolation, i.e. the enumerated types intersection::algorithm and intersection::direction. I am trying to interpolate from a parallel cyclicPolyPatch to a polyPatch while ensuring that the face normals are pointing in opposite directions (since there are two possible matching faces on the cyclic patch). intersection::VISIBLE seems to work for my simple test case but I need to make sure that this is going to give me consistent results. Thanks in advance Ivor |
March 7, 2011, 13:43 |
Sandeep Menon
Rep Power: 25 |
I think I can take a guess: The type of algorithm basically gives you a trade-off between robustness and efficiency - a choice that is left to you. Naturally, a VISIBLE option would be more efficient, since only the face-normal direction is considered during intersection calculations in triangle.H. The visible approach would probably be most appropriate for patch-type calculations, but if you have weird geometry situations, you might have to reconsider.
The same applies to the VECTOR / CONTACT_SPHERE options in face.H |
March 9, 2011, 09:52 |
Ivor Clifford
Thanks Sandeep,
I'll have a closer look at triangle and see what I can find out. |
units of geometrical parameters lost | SoobY | ANSYS Meshing & Geometry | 2 | January 10, 2011 03:58 |
Validity EWBM parameters | luuk.thielen | Main CFD Forum | 0 | July 13, 2010 03:09 |
Coal Particle Tracking Parameters | Michael | FLUENT | 1 | December 1, 2007 14:51 |
New to CFX-need explanations about mesh parameters | Cyril | CFX | 3 | November 24, 2006 06:33 |
expert parameters of SST model? | David | CFX | 1 | December 2, 2005 06:36 |
