-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Problems with "polyTopoChange" on parallel?!? (http://www.cfd-online.com/Forums/openfoam-programming-development/86094-problems-polytopochange-parallel.html)
daZigeiner March 14, 2011 11:05
I'm currently working on a mesh refinement based on the (undoable-)meshcutter class, in order to chose refinement-directions explicitly.
With one core refinement/ unrefinement and buffering works very fine. Problems only occur in parallel computing:
-if the topological change is within the processor domain everything runs great
-as the topological change reaches the processor-patches "processorPolyPatch.order" crashes with failure notice
"in patch.ProcBoundary1to0 : Local size of patch is 16 (faces).
Received from neighbour 17 faceCentres! ..."
I do not understand where the mistake comes from :confused:
Since I am initialising the "polyTopoChange.changeMesh"-object explicitly with "bool syncPar=true;"
This should invoke patchField resizeing and reordering of the face-lists in the "polyTopoChange.reorderCoupledFaces" function called by "polyTopoChange.compactAndReorder". As I understand the code, processor patches are also taken into account.
Every (even miscellaneous) reply and hint is welcome :p
Thank you,
Rudi T.
