-   OpenFOAM Programming & Development (http://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   The meanings of diag( ), source( ), psi( ) (http://www.cfd-online.com/Forums/openfoam-programming-development/86170-meanings-diag-source-psi.html)
cfd_explorer March 16, 2011 07:25
I am using the solver"porousSimpleFoam" to run simulations on a domain including porous media.
In the UEqn.H, the momentum equation is implemented as follows:
// Construct the Momentum equation
tmp<fvVectorMatrix> UEqn
fvm::div(phi, U)
+ turbulence->divDevReff(U)
Then in the file: /src/finiteVolume/cfdTools/general/porousMedia/porousZone.C
we have the following code:
scalarField& Udiag = UEqn.diag();
vectorField& Usource = UEqn.source();
const vectorField& U = UEqn.psi();
Does anyone know the exact meanings of UEqn.diag(), UEqn.source(), UEqn.psi() in details, e.g. what do these functions return? Or could anyone give some hints about that?
Thank you very much
sleepdeprivation March 16, 2011 10:46
See the source code documentation.
Here is the list of all members of fvMatrix since diag() is inheirited
http://foam.sourceforge.net/docs/cpp...ix-members.php
santiagomarquezd March 16, 2011 13:08
UEqn.diag(); gives you the diagonal of system matrix, UEqn.source(); the source term (both without applying BC's) and UEqn.psi(); a reference to the unknown field. Remember that UEqn is the whole linear system not only the matrix.
Regards.
cfd_explorer March 17, 2011 05:56
Originally Posted by santiagomarquezd (Post 299717)
Regards.
Hi Santiago.
Thanks for your reply.
In the openfoamwiki, I learn that disretization of PDE leads to an algebraic equation in the following form:
AΨ = B
So does
UEqn.diag() mean the diagonal of A, UEqn.source() mean B and UEqn.psi() mean Ψ ?
luckycfd September 19, 2013 13:53
Originally Posted by cfd_explorer (Post 299807)
Hi Santiago.
AΨ = B
So does
Please attention to this post. ?
Regards,
Hassan
sharonyue June 17, 2015 14:13
So does [/B]UEqn.diag() mean the diagonal of A, UEqn.source() mean B and UEqn.psi() mean Ψ ?
Not really, this is what Im thinking:
For example, if you are discritizing velocity, u will have an symmetry matrix. After discritization, u will have Ax = B, A will be symmetric, Then OpenFOAM will do:
[A.diag()+A.offdiag()] x = B;
A.diag() x = B - A.offdiag() x;
For symmetric matrix, A.diag() will be the diagonal of A, A.offdiag() x will be the source of A. That means if your matrix equation is like this:
A x = 0;
U also have an source() term.
