Help!! customize surface tension term in interFoam
Old   February 11, 2016, 15:59
Default Help!! customize surface tension term in interFoam
w051cxw is on a distinguished road
Hi guys, I am trying to replace the original surface tension term in interFoam using a custom code.
The original surface tension term mathematically can be expressed as Kappa*sigma*grad(alpha1). And interFoam expresses this term as fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
Based on my understanding, what interFoam does is to calculate the surface tension on face center as a scalar and then reconstruct to the cell center as a vector. Therefore, "fvc::interpolate(interface.sigmaK())*fvc::snGrad( alpha1)" is a scalar rather than a vector.
What I am trying to do is to replace the above mentioned term by another function aiming to calculate the force between any cell to the rest of the cells in the domain.
Here is my code. It complies and runs OK, but no matter how long I run the code, the results of test case does not make sense. BTW, my test case is to place a air rectangle in a liquid box and see if the rectangle can become a circle eventually. Test case does not make sense means that the air rectangle does not change its shape.
    volVectorField newSurfaceTension //create volume vector field
        IOobject
            "newSurfaceTension",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
		mesh,
		dimensionedVector("newSurfaceTension",dimensionSet(1,-4,-2,0,0,0,0),Foam::vector(0,0,0))
forAll(mesh.C(),celli) //calculate surface tension on celli
        forAll(mesh.C(),cellj) // relation between the celli to the rest of the cells in the domain
	if( ((alpha1[celli]<0.5)&& (alpha1[cellj]<0.5)) || ((alpha1[celli]>=0.5)&& (alpha1[cellj]>=0.5)) ) //if both less than 0.5 or both greater than 0.5
		s=constant1;
	else // if one is below 0.5 and the other is above 0.5
		s=constant2;
	newSurfaceTension[celli]=newSurfaceTension[celli]+(mesh.C()[celli]-mesh.C()[cellj])*s*constant3*mag(mesh.C()[celli]-mesh.C()[cellj]); // my formula
	surfaceVectorField newSurfaceTension1("newSurfaceTension1",fvc::interpolate(newSurfaceTension)); //convert from volVectorField to surfaceVectorField
	const surfaceVectorField& sf=mesh.Sf();
	surfaceScalarField newSurfaceTension2("newSurfaceTension2",newSurfaceTension1 & sf); //covert from surfaceVectorField to surfaceScalarField
constant1, constant2, and constant3 are nothing but some constants.
After that I will update surface tension term in UEqn.H and pEqn.H. Using UEqn.H as an example.
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
    UEqn.relax();
    if (pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                    //fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1)
                    newSurfaceTension2
                  - ghf*fvc::snGrad(rho)
                  - fvc::snGrad(p_rgh)
                ) * mesh.magSf()
I would greatly appreciate if anyone can give me any hint on why my code does not work.
w051cxw is offline   Reply With Quote
Old   February 12, 2016, 02:06
akidess's Avatar
Anton Kidess
My guess is you calculate the new surface tension in createFields.H - it is never updated.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 12, 2016, 02:35
Thanks for your reply, Anton. I will try to implement the new surface tension to interFoam.C rather than createFields.H then. I will keep you updated.
Old   February 12, 2016, 08:52
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Just to add more to this, the nested for loops on the order of n^2 may be slower than if you iterated over cell faces (instead of cell centers) and looked at owner and neighbour cells of that face. Look in the
$FOAM_SRC/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/LimitedScheme/LimitedScheme.C
chegdan is offline   Reply With Quote
Old   February 12, 2016, 14:55
Hi Anton,
I tried to insert my piece of code (let's call it SURFACE_TENSION and can be found in my original post) to multiple places of interFoam.C (one at a time), however, the results are still like you said before, it was never updated.... The relevant code are below. Could anyone give me more advice?
    while (runTime.run())
        #include "readTimeControls.H"
        #include "CourantNo.H"
        #include "alphaCourantNo.H"
        #include "setDeltaT.H"
        runTime++;
        Info<< "Time = " << runTime.timeName() << nl << endl;
        twoPhaseProperties.correct();
        #include "alphaEqnSubCycle.H"
        interface.correct();
        SURFACE_TENSION // first test is to insert here
        // --- Pressure-velocity PIMPLE corrector loop
        while (pimple.loop())
         SURFACE_TENSION // second test is to insert here
            #include "UEqn.H"
            // --- Pressure corrector loop
            while (pimple.correct())
                #include "pEqn.H"
            if (pimple.turbCorr())
                turbulence->correct();
        runTime.write();
Old   February 12, 2016, 14:56
Thanks Dan. I will go ahead and think about the calculation efficiency after my code works.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
VOF with surface tension and wall adhesion Agad15 Fluent Multiphase 4 December 20, 2016 17:07
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 07:34
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
